Originally posted by Class A Do you think you could have given the motor the required "massage" by turning the screwdrive slot on the lens?
Yes, I believe I have fixed my SMC Pentax DA* 300mm ED (IF) SDM lens by just turning the screwdrive screw on the back of the lens. My lens was locked near infinity and AF would not move it; and I could not move it manually, either. After reading this thread, I cleaned the AF contact points on the lens and in the camera (K-1) and used a screw driver to focus the lens out to infinity and back to minimum focus a couple times (back and forth and back and forth). It is night time, now, so I could only try the lens in the hose, but it appears to operate (at least between 5 feet and 14 feet). I'll test it outside tomorrow and add further comments.
