Originally posted by tcbubbleleo Hi, I just got given an DA*16-50mm which cannot be auto-focused on a KAF2 camera. I have no prior experience on SDM lens, have not used/seen one before. This one has no sound/noise/don't move at all when both lens and camera are in AF modes, also it shows MF on the camera. My question is: this a typical SDM prob.? or I just forget DIY repair it, and just send it in to Pentax...?
Please specify your camera.
The KAF2 mount does not support SDM autofocus, so this thread does not apply to your problem. A film camera's power contacts are for power zooms. However, the DA*16-50 should work flawlessly with cameras not supporting SDM because the lens supports screw-drive AF too. Maybe, the lens is confused when it sees power on the AF contacts which aren't SDM?
Again, please specify your camera.
EDIT: if, as Rondec assumes, your profile is correct, you have a K-x. The DA*16-50 should work of course then. But if the K-x shows the lens as MF, I guess there is a problem with contacts. Try to clean contacts on both sides. If the problem persists, try to find another body (you could visit a shop to try out a K-5) and see if the DA*16-50 still fails to work. If it does then it is a case for service.
