Originally posted by lotech Hi there,
I also have problem with the 16-50, I tried to unlock the micromotor but failed, it is very stiff hard to move, so I am planning to follow the FW hack method, but I am using the K3, I don't see a clear instruction on this model, since it is my only DSLR I don't want to mess it up, does anyone successfully apply the hack to the K3 ? I have another problem, when I open up the lens I lost the 'head-less' spring, that contact point does not make contact with the camera body but the lens' mount, it may act like some kind of grounding I don't know, I tested the lens worked fine except AF, is that ok to leave it missing ?
Ultrasonic motors are supposed to be hard to move. They work by rubbing little plastic prongs on ceramics with a direct contact. I have a device in my lab that uses US motor and moving it back and forth does help.
What helped the most was cleaning the ceramic tracks with methanol, but it might be impossible to do if the motor is enclosed in some sort of casing in a 16-50.
