01-25-2011, 10:33 PM   #1
wshi's Avatar
Comparing samyang's 8mm fisheye and 14mm rectilinear
Hey guys. I've been thinking of expanding my kit to have an ultra wide angle without breaking the bank. I think I've settled on the rokinon/samyang 8mm fisheye. Why? Because apparently, with some PP magic, it's possible to get images from the 8mm fisheye that are almost identical to images from the 14mm rectillinar, on full frame.
These images are not my own, but some I found on flickr (from a user Juan Antonio ) that conveniently demonstrate the focal length differences. Using PTlens, here are my results:
PTlens used with 136 distortion correction, 38 crop, and 3.5 horizontal shift.
Assuming that Mr Capů didn't crop his images, this is simply amazing to me. I believe the 8mm is so wide that it takes a healthy crop to get to 14mm on FF, and as such the resolution in the corners is decent.
Let me know what you guys think... yes it'll probably be annoying to have to process every image, but this really just adds to the versatility of the lens- fisheye when you want it, decent ultrawide angle when you need it.
01-25-2011, 11:49 PM   #2
great lens, you can also do spherical panoramas with it... takes 4 vertical shots + 1 shot at the sky, and then some stitching using software that is aware of this lens...
however, crops lack detail of the wide angle lens, so if you want that, maybe you should give it some more thought... not that 8mm isn't sharp - just everything is very small, obviously.
I think it's best to have both but if I'd have to choose I'd pick 8mm, but it's just me - i prefer to just make a panorama instead of composing a good wide angle shot
14mm, 8mm, angle, crop, fisheye, guys, images, k-mount, pentax lens, ptlens, slr lens
Samyang 8mm F3.5 Fisheye Lens mcjm78 Pentax SLR Lens Discussion 28 10-19-2010 08:25 AM
Rectilinear vs fisheye wide angle question PentaxPoke Pentax SLR Lens Discussion 23 09-03-2008 10:45 PM
Wide angle: rectilinear or fisheye? mikem Pentax SLR Lens Discussion 18 05-24-2008 09:48 PM
All times are GMT -7. The time now is 03:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
