Originally posted by excanonfd Looks like you have sticky diaphragm, if you could remove the glass elements and get to the aperture blades try applying liberal amount of lighter fluid to the blades and let it drain/evaporate while working the aperture blades. I don't have this lens but lighter fluid worked wonders with CZJ 180/2.8. I repeated the process of applying lighter fluid to the blades and letting them dry three times before I thought the blades moved as they should.
Hope this helps,
Definitely worth a try. Thank you for the suggestion. I was hoping that it would have to do with springs. Only because I am able to access two springs without having to dismantle the entire lens.
If I'm fortunate, somebody with knowledge of this lens will chime in with some steps.
