Originally posted by Ash I just see no need to hold back from getting the lenses that suit your needs to a tee because of any inherent AF problems when they can be rectified in repair under warranty.
Originally posted by Loren E By the way you said "inherent AF problems"....so does this mean you think AF problems are inevitable with this lens? (not talking about in many many years)
I believe what Ash meant is that if a particular lens suits your needs extremely well because it has your desired focal length range, has outstanding IQ and is weather sealed, you shouldn't necessarily pass on it just because it
may have problems later that can easily be addressed under warranty.
As to whether AF problems are inevitable, the answer is no, it's not inevitable in the sense that many people own SDM lenses and never have a single issue. It is, however, much more likely that you'll have an AF failure with a DA* lens compared to a more conventional screw driven lens. The exact amount of risk is unknown, but my personal opinion is that if you want a DA* lens, buy it, and just be aware that you may have to have it serviced at some point if there is an issue. If you don't want to deal with the potential for failure, then I would advice staying away from DA* lenses as that's the only guaranteed way to avoid an SDM failure.
