01-30-2011, 05:14 PM   #1
Rusty Rat's Avatar
60-250mm opinions
Been doing more with moving subjects lately using the longer end of my telephoto lens (all camera motor driven AF) and I can't say I'm real happy with the AF hunting. Out of 250 shots recently, maybe 20-30 were acceptable. Manual focus with them isn't an option thanks to skinny focus rings that don't work well with gloves and other issues. My MF lenses have been hamstrung by the wonky meter produced by my change of focusing screens on my K20.
All that to say I need a better (as in faster, more positive AF) longer telephoto zoom option.
Will the 60-250 do the job or should I look elsewhere?
Here's a sample of what I'm trying to do . . . shot with the WR 50-200
PENTAX K10D  Photo
01-30-2011, 05:33 PM   #2
I understand your pain. My 55-300mm hunted like a dog with my K20. I have recently acquired a K5 and have not used that lens with it yet. I will say that all lenses are capable of hunting. Have you tried the center point focus? I use it exclusively for wildlife unless I am trying to get BIF pictures, then I use Multi point focus. I also use F8 almost exclusively with the Bigma as it gets a little soft wide open. Your picture actually looks pretty good on my monitor. If you are interested in birds, I would suggest trying to find something like a Sigma 50-500mm or even the DA*300mm with a teleconverter. I own both and they are very capable lenses. You do need a monopod or tripod with them though.
01-30-2011, 07:01 PM   #3
Rusty Rat's Avatar
Gary, you're right in that I should be using the centre point focus more than I do. I'm getting too ambitious in trying to get focus, composition, and focal length all correct with a subject that stays still for just a second or so. Better to just put the pipper on the bird's head and worry about the rest when I get home.
I'll look into the Sigma as well. Thanks
01-31-2011, 10:28 AM   #4
Rusty Rat's Avatar
Gary
With the Sigma OS, do we shut off the in-camera shake reduction?
I'm looking at either the 120-400 or the 50-500. The former has the edge for me being cheaper, smaller, lighter, 77mm filter (which I already have) and a tad quicker.
01-31-2011, 11:27 AM   #5
SpecialK's Avatar
QuoteOriginally posted by Rusty Rat Quote
Yes, we do. I prefer using the SR, however, for a few minor reasons.
01-31-2011, 01:22 PM   #6
You have to use only in lens or in camera. Not both at the same time.
02-06-2011, 12:31 PM - 1 Like   #7
Hi,
I once did this test with my K-7.
I'll need to redo this with my K-5.
Hope it helps.
Cheers, Bert
YouTube - Pentax K-7 focus speed: DA* 60-250mm versus DA 55-300mm
02-06-2011, 01:10 PM   #8
Tom S.'s Avatar
QuoteOriginally posted by bymy141 Quote
Hi,
Hope it helps.
Cheers, Bert
Bert, that was interesting and I'll be looking forward to see how the K5 does.
02-06-2011, 02:22 PM   #9
QuoteOriginally posted by Tom S. Quote
The interesting thing here is that my DA* 16-50 focuses so much faster than the DA 60-250mm. Not because of the camera, but because of the lens.
The 55-300mm vs the 60-250mm is more or less the same on the lens focus speed, however the K-7 does a lot less focus hunting with the 60-250mm than with the 55-300mm.
- Bert
02-06-2011, 03:53 PM   #10
Ole
Ole's Avatar
I found the 60-250 extremely accurate in focusing with my K-7 and K-5 with no hunting (until the SDM motor died, that is). Perhaps not as fast in auto-focus as an FA* lens, but quite respectable.
I now obviously use it in manual focus mode only but the image quality is top notch so I'm considering getting the SDM motor fixed.
02-07-2011, 08:21 AM   #11
Tom S.'s Avatar
- Bert
Could it be because the 16-50 lets more light in enabling quicker focus? Unless you manually stop both lenses to the same F setting (and keep it there during focusing), the 16-50 will always get more light to the sensor.
02-07-2011, 09:13 AM   #12
alexeyga's Avatar
QuoteOriginally posted by Ole Quote
First time I'm hearing about SDM failure on the 60-250.... sad thing that is...
02-07-2011, 02:52 PM   #13
Ole
Ole's Avatar
Yes, I had thought/hoped that the 60-250 was a newer and better generation of SDM.
02-07-2011, 02:55 PM   #14
Loren E's Avatar
I was hoping so too because I have one arriving thursday.....
02-07-2011, 06:05 PM   #15
JHD
The truth is there is no new or better generation of SDM.
af, focus, k-mount, option, pentax lens, slr lens, telephoto
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
PENTAX 18-250mm VS QUANTARAY 70-300mm@250mm charliezap Pentax SLR Lens Discussion 7 02-08-2010 11:38 PM
All times are GMT -7. The time now is 11:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
