Originally posted by sewebster
Hmm, that's a cool idea to use the 50 for, reverse macro work, can leave it set up and not have to screw on a pentax lens... not that it takes so much effort
That can seem attractive at first. The cons: When I got more than a few non-Pentaxable lenses, I had to ask myself, Just how many macro lenses do I need? Somehow I just didn't feel like comparing my bunch of Minolta, Konika, Canon, LTM, Petri, Fujica-X, and Miranda glass to see which reverses the best. And they all have such small working distances, reversed. And enlarger lenses are cheaper and easier to use. So I don't keep the luzers for extreme closeups.
Originally posted by clockwork247
for the most part, lens from different brand can't be use on other brands...
And that is so. Unadapted, most can only be used for closeups, if at all. Other than M39 and M42, the lenses I've adapted to PK mount are:
* Nikon non-AF: Dremel-away the "nub-and-arc" islands on the aperture ring.
* OM and C/Y: Use a Dremel to taper the bayonet flags to fit under the PK lugs.
* Exakta: Glue M39-M42 ring onto bayonet. Grind <1mm from M42-PK adapter flange.
* Petri: Remove the lens base. Glue on a M42-PK adapter.
* Argus C3: Drill hole in PK body cap. Glue lens into place.
* Some enlarger-projector-folder lenses: Same as Argus C3.
Some have reported conversion success with removing the base from Nikon, Olympus, Minolta, and other lenses, are replacing them with a flanged M42-PK adapter, or with the PK mount scavenged from a junked lens. That is too much surgery for my limited skills. There is also the Leitax project, for converting Leica R and other lenses. That's too much money for my budget.
So, without a machine shop and/or money, only a very few non-Pentax mounts can be adapted to PK. And that's partly why I like bellows, tubes, and enlarger lenses.
