Originally posted by 006 interesting.. how can I tell the older M version from the newer one?
Conventional wisdom holds the A series 28mm is marginally better optically than the M series. Both are very good and I suspect if one were to put an image from each side by side I doubt anyone would be able to tell the difference. There is a big difference in build quality however. For the most part, aside from A* lenses, the M series were better built. The K series were better still as far as build quality goes with the Takumar's in a class by themseleves. In any case the M series 28/2.8 is all metal while the A series has some plastic bits, an updated optical formula and the A setting. The version 2 M series 28/2.8 is the only lens in the series which is not all metal.
Personally, I prefer the look and feel of the M to A series but this is subjective. Certainly the A series gets the nod for convenience. As for telling the difference between the two 28mm offerings Bojidar Dimitrov's Pentax Page gives good guidance.
See links below.
Version 1
M 28/2.8 (version 1)
Version 2
M 28/2.8 (version 2)
Tom G
