02-12-2011, 12:29 AM   #1
CPL for DA 40mm limited?
Just picked up a new DA 40/2.8 from Adorama (super excited to start using it), and wanted to seek some advice regarding CPL use with this lens. As I understand, one may use a 49mm filter size (without hood) or a 30.5mm filter size (with hood). I intend to keep the hood on all the time, and use a CPL quite frequently, so plan to get one in the 30.5mm size. I usually use Marumi, but doesn't seem they make filters in this size. Can anyone recommend a good alternative? I saw B/W MRC at B&H for $85-90, but would love to keep it a little cheaper than that if possible. Any thoughts?
Thanks,
Brandon
02-12-2011, 03:11 AM   #2
With DA 40mm limited, you ca use both the filter and the hood at the same time. The hood attaches to the lens with a stadard 49mm thread, so you can screw it on top of the filter. That's what I have done and like you have found out, it is difficult to find 30.5mm filters.
DA 21 limited is a different case. You simply can not use the lenses own hood with a CPL filter.
02-12-2011, 08:23 AM   #3
QuoteOriginally posted by Arto Suomi Quote
Exactly. Just screw the hood into the filter and turn the hood. Works like a charm.
02-12-2011, 04:01 PM   #4
Awesome! Glad to hear I won't have to buy another filter size, but can just use the same 49mm that I'll use for my DA 15/4.
Thanks,
Brandon
02-12-2011, 04:12 PM   #5
paperbag846's Avatar
You can, but I have noticed vignetting with the hood + filter attached. Not really a big deal, but I like this lens in particular best naked.
02-13-2011, 03:34 PM   #6
twitch's Avatar
I've used a 49mm ND filter on the 15 & 21, and a 49mm CPL filter on the 40 & 70. The only issue is with the 21 I can't use the hood with a filter, so it flares if it's pointed towards the sun.
cpl, da, da 40mm, filter, hood, k-mount, pentax lens, size, slr lens
CPL filter questions for FA 31mm limited PentaJP Pentax SLR Lens Discussion 6 09-21-2014 07:02 PM
FA 31mm limited, FA 43mm limited, 40mm F2.8 Sheridan Pentax SLR Lens Discussion 14 07-28-2010 12:30 PM
35mm Limited or 40mm Limited? I'm very torn manowar1978 Pentax SLR Lens Discussion 18 04-04-2010 04:06 AM
Any advantage to 40mm limited over 35mm limited? nixcamic Pentax SLR Lens Discussion 19 10-16-2008 08:36 AM
For Sale - Sold: 21mm Limited $365, 40mm Limited $215 frostugh Sold Items 1 05-27-2008 06:08 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
