Originally posted by arne.oestlund And what is the focal length of a Q lense conpared to a MF lense?? As I stated in my previous post, bokeh depends on focal lenght and aperture. If you have a certain lense it projects the same image independent of sensor size, as long as the distance between lense and sensor are the same, as they are if you compare APS-C and FF sensors. Otherwise the infinity mark on the lense would not be the same.
Deph of field also depend of viewing size and so framing. To keep the same deph of field comparison means that you'll print say all your Q image on 10"x15" and all your MF image on 60"x90" and if one day you buy an APSC sensor, you'll obviously print them at 31"x47"...
Also if there a full body portrait on the 645Z, there would just the shirt pocket on the Q picture.
Your hidden hypothesis is that magnification stay the same and viewing size and framing is proportionnal to sensor size. This allow you to say the deph of field doesn't change. But also mean you don't care of what picture you take at all.
My hidden hypothesis is that the framing is important, that as a photographer you have an objective like taking a headshoot or taking a wide landscape and that you'll display the picture the same independantly of the original sensor but more depending of the medium in use. If you look at a photo on Pentax forum with your mobile it will have the same size regardless if it was taken with MF or Q... And if you display it full screen on your 24" monitor it will be the same size again for MF or Q. If you decide to print it and put on a wall and decide for a 30"x45" you'll not change your idea to print 180"x270" because this time you used the 645Z instead of the Q.
I think my hidden hypothesis is more pragmatic than yours. But that's just me.
