10-14-2007, 07:52 PM   #1
I Bought A 16-45 And A 50-200 Today
I went to B&H today to get the 16-45, and convinced myself that I also needed a longer lens, so I bought the 50-200 too.
Hey, you weren't there to stop me, so I bought them both.
Here are a few shots from the 16-45. These were just quick grab shots; normally, I would use a tripod and meter a little more carefully, but I just wanted some test shots.
Exposure info is on the top of each photo.
16mm f6.7 @ 1/250 sec ISO 400
19mm f6.7 @ 1/350 sec ISO 400 Mmmm...'59 Corvette!
45mm f6.7 @ 1/125 sec ISO 400
So far, I like this lens.
Some images from the 50-200 to follow.
Mike
10-14-2007, 08:06 PM   #2
Here are a few from the 50-200.
95mm f5.6 @ 1/180 sec ISO 400
88mm f5.6 @ 1/180 sec ISO 400
58mm f5.6 @ 1/180 sec ISO 400
80mm f6.7 @ 1/350 sec ISO 400 This one is my favorite of the day.
I think the 50-200 will make a pretty decent portrait lens in the 50-70mm range @ f4 to 5.6.
True, it's not going to have the bokeh of f2.8, (which I'll miss) but I think it'll do fine.
We shall see.
I won't have any more test shots until next weekend, when I can shoot again.
Enjoy.
Mike
10-14-2007, 08:20 PM   #3
One more thing: Here are two shots of the same house, the first taken with the 18-55, and the second taken with the 16-45.
Which of the two do you like better?
Why?
All comments/opinions welcome.
18-55 18mm @ f5.6 1/125 sec ISO 400
16-45 16mm @ f8 1/125 sec ISO 400
Mike
10-14-2007, 10:09 PM   #4
MJB DIGITAL's Avatar
wow three hours with no reply whats going on here....
i like the second one with the 16-45 better.
the reason is that in the first shot with the 18-55 the highlights are [almost] blown...if not, they are blown all the way
but to preserve its reputation, you have shot those with the 18-55 at 5.6 while you shot the same shot with the 16-45 at f8
so you kind of did an uneven test
however, i like the shot at f8 because the highlights arent blown
Mitch
10-15-2007, 12:05 AM   #5
The 16-45mm seems to better represent fine detail. Both lenses seem to have a fair bit of CA; the 18-55mm seems worse upon closer examination. But if both were handed to me in a 5" X 7" print I would have a hard time discerning any significant differences. However, I do have to agree with MJB Digital that to properly assess both shots should have been at the same settings. But the differences between f5.6 and f8 for this experiment is pretty darn close.
10-15-2007, 03:37 AM   #6
QuoteOriginally posted by MJB DIGITAL Quote
Mitch
Hmmm...
You know, I never thought about making sure both tests were done at the same aperture.
I'll have to make sure I do this with the next test.
Thanks, Mitch, you too, J. Scott.
Mike
10-16-2007, 04:24 AM   #7
I own both of these lenses, and the 16-45 is a permenant fixture on the K10D. I think the 16-46 is a slightly better lens as far as sharpness, BUT i get some very good pictures from the 50-200.
For the price and build quality, i think they are worth having.
Not as good as my 77 but..........
Dave Brooks
10-16-2007, 06:22 AM   #8
You did crop the 16mm shot, right? Do you mind posting a comparison between the wide angles on both lenses?
10-16-2007, 04:25 PM   #9
QuoteOriginally posted by ricardobeat Quote
No, both shots have had absolutely nothing done to them.
They were both shot with the color/contrast/sharpness options at zero, 6mp jpeg.
I took both pictures from as close to the same spot as possible, although the 18-55 shot was taken about 24 hours before the 16-45 shot.
If you look closely at the corner of the porch, it's more exaggerated in the second (16mm) shot.
I'm going to try to do a fairly thorough test this weekend between the 18-55 and the 16-45 with the camera on a tripod, and all settings the same. I'm also going to test the 50-200.
Mike
10-16-2007, 05:08 PM   #10
QuoteOriginally posted by pentkon52 Quote
Dave Brooks
I agree, even though I hesitate to rate anything when I've had it for such a short time.
The 16-45 feels as though it's more solid than the 18-55 (it should - it's 4x the price! ) but the kit lens is still a good all-around performer. One thing which I read about here first, but still surprised me is how far out the 16-45 extends at the wide setting!
I was looking for one fast lens in the 18-50(70) range, and then I thought to myself that I might be better off with two more moderately priced lenses covering a wider range, and gave up chasing the coveted and elusive f2.8 until I get a prime or two.
I really like the overall feel, and the images I've seen from the 50-200 so far.
Hopefully it won't rain, so I can get some decent outdoor shots from each lens this weekend.
So far there's not much color on the leaves here in Queens, New York this autumn, but they should start turning soon. Can't wait for that!
Here's a very good map of Queens County. Enjoy.
map
Mike
10-16-2007, 05:14 PM   #11
QuoteOriginally posted by Mike Bokeh Quote
Did you take those two at different angles?
The 18-55 one has more on the left side, see the skeleton. That's why 16-45 one looks like cropped.
10-16-2007, 05:21 PM   #12
QuoteOriginally posted by ddhytz Quote
I stood in what I remember to be the same spot (the same opening in the wrought-iron gate in front of the house) and tried as best I could to compose the same image.
But no cropping was done.
Mike
10-18-2007, 12:29 PM   #13
hinman's Avatar
Very nice pictures
Mike,
Those are very nice pictures. Hmm, now I think you may have to use your DA 18-55 much less. Congratulation on your copy of DA 50-200, I also get a good copy of the lens, and you can see my thoughts along with others in my gear list for DA 50-200
Inexpensive gear with Pentax - Hin's Tech Corner
Photozone.de Pentax DA 50-200 review - Hin's Tech Corner
I share the similar thought that I can use it for portraits in the 50-70 range, I actually find it very useful from 50-90 range with my boys for indoor
Portraits with Pentax DA 50-200 - Hin's Tech Corner
Thanks,
Hin
10-18-2007, 08:19 PM   #14
QuoteOriginally posted by hinman Quote
Mike,
Thanks,
Hin
Thanks, Hinman, but these were just test shots, although I did like the results so far.
Hopefully the weather will cooperate, and I'll have the time to do some decent tripod-mounted shots of all the lenses at the same apertures this weekend.
Mike
10-19-2007, 05:35 AM   #15
axl
axl's Avatar
so you kind of did an uneven test....
good point, it's hard to be honest if they are at different f stops... anyway 16-45 has reputation of better and sharper lens, I just can't justify it's purchase so I'm sticking with 18-55 which is decent performer especialy stopped down....
I'd really apreciate that too, I compared those two in shop and it didn't seem to me as such big difference, but would love to see propper wide angle comparison shot on some landscape or so....
do you have any? pleeeeeeeeeeaaaaaaaaaaaaase....
Mike
It's not exactly the same spot, unfortunately...
or the framing is bit different, hence it's harder to comapre them...
different time of the day, different day, and maybe different framing would affect metering, so I would assing blown out highlights from 18-55 shot to these... but maybe I'm wrong...
regards....
f6.7, iso, k-mount, lens, pentax lens, sec, shots, slr lens
I bought the cutest little FF camera today little laker Canon, Nikon, Sony, and Other Camera Brands 14 06-04-2010 06:26 PM
Bought my first ltd today! 70 f/2.4 PentaxPoke Pentax SLR Lens Discussion 16 02-10-2009 10:40 AM
I just bought a used K10d so here's some photos from today pasipasi Post Your Photos! 5 09-17-2008 07:32 AM
Just bought my K10D today Mister E Pentax DSLR Discussion 5 02-02-2008 07:06 AM
Bought a tripod, today. NLAlston Pentax Camera and Field Accessories 1 05-14-2007 05:33 PM
All times are GMT -7. The time now is 01:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
