Originally posted by MrZeroPing I use my M's because they are hand me downs from my father. I have a range of 28mm, 50mm, and 135mm. However, there are times when they make me want to pull my hair out. I'm not very good at focusing with them and can't consistently get good shots. So I would like to ask some questions.
How do you get consistently good pictures with manual focus? Practice? Skill? Any tips? I'm using the K20 with a *ist screen for good exposure.
Also aside from pressing the green button for taking exposures are there any other ways? Any insight would be quite appreciated!
Hello MrZeroPing!
I often use a type of focus bracketing; your K20D has focus confirmation, and it takes the form of a light that comes on in the viewfinder when it's 'aquired' a focus target, and then a green hexagon when it's determined that the image is in focus. Problem is, this hexagon usually stays 'on' through a certain degree of lens focus throw (meaning, you can turn the focus ring slightly further after the hex appears, and the hex will still be there.)
What I often do is to take a snap right when the hex first appears, focus all the way 'through' the hex appearance to when it disappears, focus back a bit and snap. Sometimes, if it's a relatively long throw, I'l also focus right about to the middle of the hex appearance and snap. This will give me two or three shots of the subject, and one of them will have the subject razor sharp, or two or all three depending on the DOF.
Later you may see patterns in the way a certain lens performs. For example, I know my M85 f2 on my K20D usually achieves best focus right at the end of the green hex appearance, so I usually just snap there and skip the bracketing with that one. (I think if that copy were an AF lens, it might be a notorious front-focuser
With your wider lenses, you can often just take advantage of the hyperfocal focusing, which is a different aperture and distance with each lens... with your M 28, you can set it at f/8, focus to infinity, and then anything farther away than about 15 feet (IIRC) is in focus. That's how that duck/lake shot was taken. Using them like that makes the wides very easy-to-use walkabout lenses.
Hope this helps!
