Originally posted by selar Liveview is the best manual focusing aid available on the newer dslrs that have the option. In manual focus mode, you can zoom in 10x (k-x) on the exact spot of the image you want in focus and adjust the focus till you nail it. Its accurate because you are using the actual sensor as a focusing aid. All other methods, AF beep, focusing screens etc., depend on being the exact same distance as the sensor, in the light path through the mirror box. Also solves the difficulty spectacle wearers face in using the optical viewfinder. No exercises required as well
Once you enter liveview mode, press the info button. The wheel will then allow you to change the magnification.
Yes, I wish I had Live View, though I much prefer taking shots with a viewfinder to my eye. What we actually need is a Pentax EVIL camera, preferably with KAF mount and in-body SR, but otherwise similar to a Panasonic GF1 (though it would need to be bigger).
Mind you, I can imagine at x10 magnification, things could get a bit tricky with a long lens, hand-held - perhaps it's at its best with the wider-angle lenses (which are otherwise very tricky to focus)???
By the way, the AF beep is independent of the mirror-box path length (the AF sensor is at the bottom of the camera). As to why it's so incredibly variable in its accuracy with MF lenses is a mystery to me...
