Originally posted by elho_cid Respectable manufacturers just do not put "macro" in name of lenses that do not achieve at least 1:2.
- If you are going to play strict (fine by me) then stick to the 1:1 minimum magnification for macros (-> Wikipedia). Why make an exception for 1:2 lenses? Either or, AFAIC.
- The trick must be not to include the "macro" in the name, but printing it on the lens barrel of a lens with just 0.11x magnification is OK. Phew, lucked out there, Pentax.
- Just found this shocker from Pentax: "Macro" in the lens name and not a 1:1 magnification.
Seriously, I don't support fraudulent labelling and I'd prefer if only 1:1+ lenses would receive the macro designation. I only pointed out that the Sigma 28/1.8 isn't that far off of a magnification that is sufficient to allow other lenses to be called macros without sniffing at them. To imply that Pentax is a self-respectable lens manufacturer given the two examples above whereas Sigma isn't, well, doesn't make sense to me.
At f/4, which is not a high f-stop for a close focusing scene (DOF) the Sigma 28/1.8 is extremely sharp so it can well be used for "macrops", i.e., gaining further magnification by cropping.
Originally posted by Pentaxor what stopped me is the knowledge that other lenses are better than it with regards to overall IQ performance.
And how did you obtain that knowledge?
To be honest I doubt you are as informed as you could be, e.g., if you tried the lens yourself. But that's OK. I don't need to convince you. I was just wondering what formed your opinion.
Originally posted by Pentaxor ...I wasn't impressed at all with the images I have seen.
Well the
sample images on the Sigma website are sufficiently impressive for me. Don't mistake the second image with a macro!
Just kiddin.
Originally posted by Pentaxor this is the reason why I said that the slower zooms are much better if someone is looking for very good and consistent performance.
Much better? Really? Unless you can report first hand experience and show us why the images of your slow zooms are much better than the images of a Sigma 28/1.8 then I'd abstain from such statements, if I were you.
