02-18-2011, 03:44 PM   #16
Ira
QuoteOriginally posted by Dubesor Quote
I haven't yet used a V700/V750 or Nikon ED scanner yet, but I beg to differ with regard to V500/V600/8800f/9950f and similar class flatbeds.
Pretty sure this 'DSLR scanner' will beat them in speed and workflow, but also dynamic range and image quality.
There's a reason that transparencies are still scanned conventionally for professional work, and not shot with a camera.
02-18-2011, 03:49 PM   #17
Dubesor's Avatar
A professional drum scan for professional work is not the same as a home flatbed scan, and hardly a 'conventional' process. Likewise with Imacon scans.
I'm aiming for quick scans for web use here; can't be bothered with the tedious scan workflow for the time being; life's too short.
For exhibits and publication, I can get very high quality, very large scans from this film, having access to a drum scanner.
For me, the DSLR method is quite a bit better than my dinky Canon 8800f. At web sizes, I doubt anything can beat it.
With nicer equipment and different aims for your scans, of course YMMV.
PS here's the corrected version of the image posted earlier, as shot with the K-x. Good enough for me ...
02-19-2011, 12:20 PM   #18
Stone G.'s Avatar
Came to think (you may be aware of this already): You can possibly have an even smoother workflow using PK-Tether:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/130089-tethering-app-works.html
Steen G. B.
03-14-2011, 02:04 AM   #19
Dubesor's Avatar
Yes, tethering would save lots of time.
But I'm still struggling with the initial setup. I have a lightbox now with a nice even diffused source of 5000K light. However, the camera needs to be so far away from the film being "scanned" (28cm) that it actually gets reflected in the film. I tried using a bellows to cut sidelight, but it didn't work (more on that here).
03-14-2011, 06:14 AM   #20
steve1307's Avatar
After reading this and much other material, I just convinced my 70.. er...something year old father to get himself a Plustek slide/film scanner to digitize a few thousand of his slide transparences from the 60's.
It will be a tedious process to scan (his part) and tedious also to set up the software (my part) but I am hoping the results are decent.
I briefly considered buying a new slide duplicator like Dubesor here and using my DA35 but the Plustek scanner wasnt so expensive and i think might get at least more consistent and easier results.
I will endeavour to post samples somewhere here if it works .
..or alternatively to ask for help if it doesn't work.
film, k-mount, lens, light, macro, macro-takumar, pentax lens, slides, slr lens
Home Slide Scanning vs Lab Digitizing Question Biff Digital Processing, Software, and Printing 7 01-29-2011 10:28 AM
digitizing slides?... beaumont Film Processing, Scanning, and Darkroom 17 01-29-2011 10:14 AM
Bellow/Macro setup for slides/negatives allyn Pentax Film SLR Discussion 7 01-16-2011 06:56 PM
Digitizing Slides Question Tamia Digital Processing, Software, and Printing 11 02-12-2010 01:31 PM
digitizing slides with a dSLR ryno Pentax Film SLR Discussion 16 06-01-2009 05:05 AM
All times are GMT -7. The time now is 02:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
