02-17-2011, 10:00 PM   #1
k-mount MF wide-angle shift lenses
I've long wanted to get one of these.
The only available Pentax OEM lens seems to be the K-series SMCP f2.8/35mm Shift.
Are there any others I'm not aware of? Are there non-Pentax shift lenses that are as good/better?
The e-bay prices seem to be in the 590-1000+ dollar range. Beyond the usual checks re optics, scratches, alignment, rattles, fungus, etc., are there any specifics of the shift lens, for example about the built-in filters or whatever, that I should be looking at?
Any advice would be very appreciated.
02-18-2011, 06:23 AM   #2
boriscleto's Avatar
There is a shift adapter to use Pentacon medium format lenses as shift lenses.
There is the PCS Arsat 35mm f2.8 Shift Lens made in the Ukraine.
The Loreo 35 mm f11-22 Shift lens (Lens-In-A-Cap)
The newest are the Schneider-Kreuznach Super Angulon 28mm f2.8 Shift Lens (2008)
(The mechanism uses an adapter for different mounts as part of the design, but without adapter cannot be used, similar to the Adaptall)
Tilt-Shift lenses other than Lensbaby.
The Zenitar MC 35mm Tilt & Shift f2.8 (2008) and the Zenitar MC 80mm Tilt & Shift f2.8 (2008)
Schneider-Kreuznach also announced two new tilt-shift lenses at Photokina.
PC-TS Super-Angulon 2.8 / 50 HM
PC-TS Makro-Symmar 4.0 / 90
02-18-2011, 07:29 AM   #3
Groucho's Avatar
There's also Hartblei... in K-mount, they've got a 40mm F4, 80mm F2.8, and 120mm F4 macro. Their old site shows the 35mm F2.8, 65mm F3.5, 80mm F2.8, and 120mm F2.8. The old site also lists the Arsat 35mm F2.8 and 80mm F2.8.
I have no first-hand experience, but it appears that the Hartblei stuff is very high-quality and priced to match. Their new stuff uses, from what I understand, Zeiss medium-format lenses stuffed into a t/s body for 35mm use and has approval from Zeiss.
02-19-2011, 01:06 PM   #4
Thank you both. Lots of options to consider.
The price range for shift lenses means my budget will take only a used one.
Let me repeat my other question. Do shift lenses have, due to their complexity, any partical usual weak points of their own, beyond the common ones such as scratches, fungus, etc., that I should look at/evaluate?
02-19-2011, 02:19 PM   #5
I don't know the answer to your question, but am also interested in this and wish Pentax would maybe build a few more of these lenses for us to play with.
There's another post you should look at here: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/24004-my-self-...t-bellows.html
It'd be a fairly cheap way to play around with tilt/shift.
The only weak points I'd look for is the actual rotation and shifting mechanism on the 28/3.5 shift lens. Make sure the oil hasn't gummed up, gathered much dust, or loosened up over the years. I imagine most of the ones you find out there will be in good shape as I don't think many people who have these use them all that often.
02-20-2011, 10:18 AM   #6
gofour3's Avatar
QuoteOriginally posted by asaru Quote
Yes as previously posted most people who owned a K28/3.5 Shift probably did not use it very much, so it’s easy to find one in excellent condition with everything working. Hence the high prices of $500 to $900.00 for a used one. It’s a great lens on film, not sure on the FL for an APS-C DSLR, won’t be wide enough.
Phil.
k-mount, lens, lenses, pentax lens, shift, slr lens
Wide Angle K-Mount Club ajuett Lens Clubs 29 09-16-2017 07:23 PM
Testing Wide Angle Lenses mtngal Pentax SLR Lens Discussion 7 03-06-2014 02:19 AM
For Sale - Sold: Wide Angle Vivitar 19mm 1:3.8 MC lens PK/A-R mount in Excellent Condition jjdgti Sold Items 5 10-07-2009 07:59 AM
AF and wide angle lenses opiedog Pentax SLR Lens Discussion 5 08-25-2009 12:59 PM
For Sale - Sold: Vivitar 28mm f/2.8 wide angle lens with P/k mount. yb_abq Sold Items 6 02-02-2009 07:46 PM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
