02-21-2011, 07:27 AM   #16
paperbag846's Avatar
They certainly look more similar than different. I get the impression that the ultron is slightly sharper, while the DA 40 has slightly more contrast. This is, of course, after much squinting. The fact that the Ultron is f2 makes it a very different lens overall (and the nicer manual-focus).
02-21-2011, 07:33 AM   #17
GeneV's Avatar
QuoteOriginally posted by paperbag846 Quote
To my eyes, the difference in sharpness between the two is insignificant. The center crops were indistinguishable, and the corner crops I posted both showed about the same slight amount of softening. The DA40 has a warmer color rendition and the Ultron has a very usable F2. In fact, its F2 is softer than 2.8 at the corners, but not hugely so. I could have been this much off parallel to this old fence.
Due to my sloppiness, the left knot in this 100% corner crop on the VL at 2.0 is actually a tad further into the corner than the 2.8 crop.
02-21-2011, 05:57 PM   #18
dasuhu's Avatar
Flowers
First attempt at close-up test.
It was really windy, so it's kind of a fail for close-up comparison. I've included the entire frame instead of cropping, so maybe this just turned into a bokeh comparison at different apertures comparison
Will retry once the wind dies down.
Shot in PEF, converted with CS5, Liveview 10x Manual Focusing, no PP
02-21-2011, 06:03 PM   #19
Pentaxor's Avatar
QuoteOriginally posted by dasuhu Quote
It was really windy, so it's kind of a fail for close-up comparison. I've included the entire frame instead of cropping, so maybe this just turned in a bokeh at different apertures comparison
this isn't close-up and even more difficult to draw some conclusion.
02-21-2011, 06:14 PM   #20
dasuhu's Avatar
It was really windy, so it's kind of a fail for close-up comparison. I've included the entire frame instead of cropping, so maybe this just turned in a bokeh comparison at different apertures comparison
QuoteOriginally posted by Pentaxor Quote
I acknowledge that it's not a real close-up test in my previous post, due to the wind mucking everything up (I edited my original post for clarity). If I moved any closer, the DOF would have shrunk and the flower would not have stayed in focus from shot to shot for precise comparison purposes. I meant to say these shots are just for a cursory comparison of bokeh at different apertures, but I goofed. Definitely need to proof my posts before submitting.
02-21-2011, 06:25 PM - 1 Like   #21
dasuhu's Avatar
02-22-2011, 01:29 AM   #22
Pentaxor's Avatar
this is much more clearer. infinity focus does favor the Ultron.
02-22-2011, 11:00 PM   #23
dasuhu's Avatar
Short Focus Distance Test
Focused on that weird dimple on the orange (center column, and about 3/4 of the way down in crop shots). I think the focus is just a bit off on the DA40 shots. I tried my best with Liveview 10x, but it's so tough. DA LTD MF ring doesn't help either. Here's my best attempt at a close focus comparison, albeit with caveats.
Test temporarily taken down to redo
See Walnut Test Below as redo for Short Focus Test
02-23-2011, 09:21 AM   #24
GeneV's Avatar
My informal tests confirm a definite advantage for the VL at large distances. I hesitate to say infirnity, because "infinity" focus appears to begin pretty quickly on the DA40.
These cranes were about 100 yards away. Taken at F8. 1/200 (VL) and 1/400 (DA)
Full shot
100% crops
VL 40 Ultron
DA40 Ltd
I went through multiple comparison shots, and the results were similar, though not as dramatic as the birds.
Full at F8
VL
DA
I'd say my results at infinity were very similar to Daniel's.
02-23-2011, 09:44 AM   #25
I gotta get an Ultron. Especially now that my LX just arrived
02-23-2011, 09:46 AM   #26
GeneV's Avatar
QuoteOriginally posted by alan_smithee_photos Quote
My LX and MX were the reason I bought one. The focus is like buttah.
I do wonder if some of the difference between the two lenses at infinity have to do with the greater precision of focus on the Ultron. There are very few degrees between 3 meters and the infinity stop on the DA40, and the infinity stop is past infinity on most AF lenses. The Ultron offers a good deal more room to be precise in the focus around infinity.
02-23-2011, 10:26 AM   #27
While I think it's clear that the ultron is sharper (esp. at huge magnifications and large distances), I don't think the orange test is very fair - looks like the point of focus is different for the two lenses.
02-23-2011, 10:32 AM   #28
dasuhu's Avatar
I will attempt to redo the orange test...although I do think it is fair to say with the shorter focus throw of the DA LTD, the chances of getting really, really precise focus is a lot less likely than with the Ultron, imho. One slight touch at the DA LTD focus ring when at minimum focus distance drastically alters the focus plane.
02-23-2011, 10:42 AM   #29
Yeah I don't think that it's worth doing the test over again - it's good work overall, but slightly misleading.
I think when it comes down to it, the strength of the DA 40 lies in it's snappy autofocus. That's what I love about it. If you don't care for AF and prefer manual focus the ultron is overall a superior lens.
02-23-2011, 10:46 AM   #30
GeneV's Avatar
Actually, I think that is true to some extent throughout. My sense of my tests was that there are fine distinctions of focus that I was making on the Ultron that just weren't possible on the DA40. The trees behind the cranes showed a difference in sharpness between the two lenses, but not as pronounced as in the birds.
40mm, aperture, da, k-mount, pentax, pentax lens, slr lens, ultron, ultron 40mm f/2, voigtlander ultron 40mm, vs
For Sale - Sold: smc Pentax DA 55-300mm f/4-5.8 ED, Voigtlander Ultron 40mm f/2 SL-II for (Worl dexmus Sold Items 2 11-03-2010 09:14 AM
Test run images of Voigtlander Ultron 40mm f2.0 roentarre Pentax SLR Lens Discussion 57 02-01-2010 08:08 PM
which 40mm? pentax da 40 or Voigtlander Ultron 40mm f/2.0 SL-II dexmus Pentax SLR Lens Discussion 12 10-30-2009 07:26 PM
Voigtlander 40mm f2 Ultron J.Scott Pentax SLR Lens Discussion 3 07-15-2009 02:09 AM
All times are GMT -7. The time now is 09:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
