03-01-2011, 02:48 PM   #31
dadipentak's Avatar
QuoteOriginally posted by sewebster Quote
If you have a hood that is a cylinder of the same total length of the tulip then it will vignette. If you have a hood that is only the length to the cutouts of the tulip then you won't get as much light shielding. The tulip shape is "longest" where the angle of view is smallest and "shortest" where the angle of view is largest.
I gather the cut-outs in the tulip correspond to the corners of the sensor where vignetting is likely to appear when a round hood is used--right?
03-01-2011, 02:57 PM   #32
sewebster's Avatar
QuoteOriginally posted by dadipentak Quote
That's the idea.
03-01-2011, 03:58 PM   #33
rparmar's Avatar
Can you use a tulip hood when shooting other flowers?
03-01-2011, 03:58 PM   #34
rparmar's Avatar
Kidding!
03-01-2011, 04:17 PM   #35
pacerr's Avatar
Hold a tulip hood to your lens rotated 90-degrees out of normal alignment and observe the effect.
H2
03-01-2011, 04:48 PM   #36
I understand that but it amounts to only a little savings of material for the same total protrusion in front of the camera.
The best shape is probably a rectangular pyramid with cross sectional shape similar to sensor and an angle that matches the field of view of the lens. I recall seeing hoods with that shape.
03-01-2011, 05:36 PM   #37
sewebster's Avatar
QuoteOriginally posted by newarts Quote
Material savings compared to what? If they didn't make the tulip cutouts there would be vignetting if the same total length were retained.
Yup.
03-01-2011, 05:37 PM   #38
dadipentak's Avatar
I associate that shape with movie cameras.
03-02-2011, 04:39 AM   #39
I think a better way to look at it is the tulip shape cuts out light not used due to the rectangular frame.
The material savings I refer to is compared to a simple cone as high as the tulip tips at an angle that avoids vignetting.
03-02-2011, 04:41 AM   #40
glee46's Avatar
If you come across a picture of one could you post it here. My mind is having a hard time trying to picture it for some reason.
Thanks
03-02-2011, 04:43 AM   #41
glee46's Avatar
Here is a link on hoods: Lens hood - Wikipedia, the free encyclopedia
Here is a link for those DIY: How to make a hood for your lens
It helped make things a little clearer for my aging brain..
03-02-2011, 05:47 AM   #42
Optimal Rectangular Pyramid Hood
QuoteOriginally posted by rparmar Quote
How can one calculate the optimum hood depth range for a given focal length? That is, the minimum length that will do any good or the maximum length that will work with no vignetting. Of course this will depend on sensor size as well....
Here's a design for a rectangular prism shaped hood. It is optimum in the sense that there is no other shape that lets in less light from outside the field of view for the same hood height. It also uses almost the minimum possible amount of material in its construction.
The fraction of light from outside the field of view is proportional to (1+Focal.Length/Hood.height)^2, so there is no optimum height (the higher it is, the less extra light fraction enters.)
Dave
EDIT: I'm not recommending that anyone build one of these (although it'd be easy to build and I'll post a cutting template if anyone asks); rather, I'm addressing the optimum hood question. It is likely that a conical hood just a bit deeper than the optimum rectangular hood can do as well (hmmm...I'll think about this...)
RE-EDIT: I've changed the drawing to remove an error involving masking of the lens.
03-02-2011, 05:55 AM   #43
QuoteOriginally posted by glee46 Quote
Good DIY link. The proper hood height (depth) can be estimated from the relationship posted earlier:
Height = Focal.length (Top.diameter/Filter.diameter-1)
This presumes that the filter ring is just on the verge of vignetting, hence is safe but may not be optimum.
Dave
03-02-2011, 08:12 AM   #44
Lowell Goudge's Avatar
only if you promise to wear rose colored glasses
03-02-2011, 08:16 AM   #45
the big issue with respect to hoods, regardless of rectangular or petal hoods is the ability to gaurantee regestration to the sensor, to avoid unwanted vignetting at the corners.
also note that rectangular hoods, while better than circular hoods are still not optimum.
as someone stated earlier the shape of a petal hood is defined by the field of view at that specific point along the sensor . if you are shooting very close to the sun, the difference could still be quite noticebale.
depth, hood, k-mount, length, pentax lens, slr lens
Online Depth Of Field Calculator nulla Photography Articles 25 10-14-2012 07:08 AM
Depth of Field Calculator barbosas Photography Articles 19 02-11-2010 12:09 PM
Online Depth Of Field Calculator nulla Pentax SLR Lens Discussion 20 12-29-2009 04:33 PM
Blackberry Depth of Field Calculator! elcahall Pentax DSLR Discussion 9 12-11-2009 11:05 AM
Optimum Aperture Richard F Pentax SLR Lens Discussion 4 06-05-2008 10:28 PM
All times are GMT -7. The time now is 05:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
