03-01-2011, 08:53 AM   #1
ogl's Avatar
DA35/2.4 is better than FA35/2 in serious tests
http://www.optyczne.pl/221.1-Test_obiektywu-Pentax_smc_DA_35_mm_f_2.4_AL_Wstęp.html
Resolution
FA35/2
DA35/2.4
CA
FA35/2
DA35/2.4
COMA TEST
FA35/2
DA35/2.4
Advantages:
Small and compact design,
excellent image quality at the center of the frame,
decent image quality at the edge of the frame,
slight chromatic aberration,
low distortion,
very low coma,
negligible astigmatism
good work under the bright light
instant autofocus
03-01-2011, 09:00 AM   #2
enoeske's Avatar
Sharper != Better
03-01-2011, 09:01 AM   #3
ogl
ogl's Avatar
QuoteOriginally posted by enoeske Quote
Sharper != Better
less CA, almost no coma, cheaper.
03-01-2011, 09:19 AM   #4
Pentaxor's Avatar
just take note that both lenses were tested on different cameras, K20D and K-5. so that could possibly affect the MTF results.
03-01-2011, 09:50 AM   #5
imtheguy's Avatar
QuoteOriginally posted by Pentaxor Quote
I also noted they were not compared at the same apertures and although I understand why, I would prefer that head-to-head comparison shots used the same setup.
03-01-2011, 09:54 AM   #6
macTak's Avatar
I'm sure it does. They are always good about noting this so when the english translation comes out we'll know how much. But still the curves are clearly different, so there is some difference in the lenses (coma also looks clearly better, not surprising with a less aggressive maximum aperture)
03-01-2011, 10:40 AM   #7
ogl
ogl's Avatar
MTF 50 is MTF 50 regardless of sensor. IMO. By the way, the real resolution of K20D and K-5 are almost identical.
it's not PHOTOZONE tests. They calculate lp/mm with MTF50.
03-01-2011, 11:17 AM   #8
I own both
I own both lenses and have shot numerous numerous 'real world' comparison shots with both lenses on my K20D and my very subjective conclusion is that you cannot really tell the difference except that the FA 35 f/2.0 exposes about 1/3 a step higher. I had hoped that there would be at least some difference between the bokeh of the two lenses, but I really cannot see a significant difference. Couldn't find a difference in CA either. There may be measurable differences between the two lenses, but except for the previously mentioned exposure difference, I cannot SEE much of a difference between my two copies.
NaCl(close enought to identical that I will be selling the FA 35)H2O
03-01-2011, 11:45 AM   #9
Pentaxor's Avatar
QuoteOriginally posted by ogl Quote
I'm aware that it is not photozone, but lenstip has always reiterated resolution differences between cameras (not just between APS-C and FF, but also CMOS and CCD equivalence and between same sensor sizes and variance in MP resolution, otherwise they wouldn't noted what camera is used if such MTF50 results were negligible or show MTF variance between old and new cameras. I'm not so sure however what you meant by real resolution but the K-5 has considerably has a substantial MP resolution advantage that would influence lp/mm measurement.
basically, I was just saying that it would had been much easier to understand if both lenses were tested with the same camera.
03-01-2011, 01:12 PM   #10
Ben_Edict's Avatar
The URL you give, leads me to the test of the DA 35/2.4 alone, not to a comparative test. Did you copy the data from two different tests together?
Then the conclusions you draw are simply not valid.
The reviewers do not use MTF measurement equipment but simple test shots. To get comparable results this way, you need to use the same camera. The K5 and K20 seem to be too different to make a valid comparison base. This is especially true for any colour abberations, which are highly dependent on the micro lens array used on the sensor (as is vignetting, for instance.)
Also, comparing f/2.0 with f/2.4 is comparing apples and pears. It leaves out the basic, inherent advantage the faster lens has over the slower one in terms of light gathering. It is 1/2 f-stop, which can decide between getting a shrp shot and a slightly blurred one.
The only thing I can read from both tests is, that both lenses are very much worth the money and a competent choice, albeit different ones.
Ben
03-01-2011, 11:37 PM   #11
wlachan's Avatar
If you see coma at the center, does that mean the FA35 suffered from misalignment? The sudden drop at f5.6 is strange too.
03-02-2011, 01:40 AM   #12
ogl
ogl's Avatar
QuoteOriginally posted by Ben_Edict Quote
Could you use searching functions of sites?
http://www.optyczne.pl/149.1-Test_obiektywu-Pentax_smc_FA_35_mm_f_2_AL-Wstęp.html
03-02-2011, 01:58 AM   #13
krypticide's Avatar
Sharper != Better
Seconded. Sharpness is just one aspect of a lens.
Sent from my EVO 4G with CM7
03-02-2011, 12:43 PM   #14
Ben_Edict's Avatar
No, I couldn't, because my Polish is non-existent. But I have found the FA 35/2 test without the search function. The point I wanted to make is, that the tests cannot be compared, because the technical base (the sensors) are too different.
Also, it does not really make much sense to compare a fast f 2.0 max. aperture with the mediocre f 2.4 max. aperture.
Ben
03-02-2011, 01:00 PM   #15
paperbag846's Avatar
I think this might be a little overblown.
The difference between 2.8 and 2.0 is significant, but 2.4 and 2.0, well, less so.
Obviously there will be some times where it would be advantageous, but all else considered (let's say both lenses are equal aside from aperture), the price difference is pretty large for 1/2 stop. For light, 1/2 stop of ISO is not a lot of ask, and for DOF, at 35mm you aren't going to see a big difference.
In other lenses with a speed/price difference like that, the lenses usually are actually better, or at the very least different. It appears here that we have a lens that is 1/2 the price, and all you sacrifice is 1/2 of a stop.
As far as resolution is concerned - remember all that talk about the "soft" k5? If anything, the DA L on the K 5 should have been at a disadvantage w.r.t. sharpness because of the AA filter.
I don't find it surprising that Pentax might have improved on the optical design of the FA 35 after about 15-20 years.
coma, da35/2.4, fa35/2, frame, image, k-mount, pentax lens, quality, slr lens
DA35/2.4 AL and FA35/2 AL are the sisters. ogl Pentax News and Rumors 83 09-12-2010 02:47 PM
K7+FA35 or DA*55 VS KX+DA 40 surfmanjoe Pentax DSLR Discussion 7 06-30-2010 01:28 PM
FA35 available.... herzzreh Pentax SLR Lens Discussion 9 01-07-2010 05:55 PM
FA35 Bokeh k100d Pentax SLR Lens Discussion 7 03-08-2008 02:48 PM
Fa35? liketobe Pentax SLR Lens Discussion 2 04-25-2007 10:21 PM
All times are GMT -7. The time now is 01:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
