These are some rough values I got from varying the focal length and seeing what max aperture I could get;
f/2.8 from 17 to ~21mm
f/3.5 from ~23 to ~34mm
f/4.0 from ~34mm to ~70mm
f/4.5 at ~70mm
So basically when I turn the zoom ring, at just a bit before 70mm, the figure on the display jumps up to f/4.5.
Originally posted by fLyIr Especially which FL is ending with 2.8 and 4 and what aperture does 50mm have.
So the lens quite quickly loses it's f/2.8 max aperture, and at 50mm, the max aperture is f/4.0. The focal range makes the lens a quite useful everyday/walk-around lens, but if you NEED f/2.8 in that range, then you're probably better off getting one of the 16-50 or 17-50 or 18-50 constant f/2.8 lenses out there.
Hope that helps.
