Originally posted by scole I also have the 12-24 and I have the slim B+W CPL always on it. I really love its quality, so much so that I switched all the CPLs for my other lenses to B+W. I believe they run a half stop darker than Hoya's upper level CPLs and, for me, I wanted that since I talk a lot of streamside / waterfall type shots.
Do you ever notice side-to-side gradations of darkening, using the polarizer with a wide angle lens like the 12-24? Roger Cicala of LensRentals mentioned this in his article on wide-angle lenses:
A Broad Guide to Ultra Wide
"Because the angle of view is so wide, the angle at which sunlight enters the sensor will vary from one side of the image to the other, unless the sun is behind you. For example, if the sun is to your left, the left side of the sky will appear lighter and less blue than the right. Wide angles love overcast days and lots of clouds. Pure blue sky—not so much.
A polarizing filter only polarizes light entering at certain angles, so it can actually make this phenomenon worse. Unless you absolutely need it, a polarizer is generally a bad idea on an ultra-wide lens."
Anyway, a good 77mm CPL for the 12-24 is going to run you over $100!
