View Poll Results: Which lens to keep?
Pentax-F 50mm 1.4 940.91%
Pentax-FA 50mm 1.7 1359.09%
Voters: 22. You may not vote on this poll
03-12-2011, 07:46 AM   #1
Which lens should I keep?
Just wanted to do a quick poll on which lens I should keep:
Pentax-F 50mm 1.4
or
Pentax-FA 50mm 1.7
I understand they are both great lens that are often difficult to come by but I would like to get a wider fast prime, so which one should I let go?
03-12-2011, 09:24 AM   #2
SpecialK's Avatar
Which one gives the the results you like best? Sell the other one.
03-12-2011, 09:29 AM   #3
bdery's Avatar
I'd keep the f1,7, because:
1-the f1,4 will get you a higer selling point
2-the f1,7 is sharper wide open than the f1,4 at f1,8
3-it's more of a rarity
The f1,4 does give you a wee bit more speed, and a wee bit smoother bokeh, but is less sharp at wider apertures (they're about equal starting at f2,8)
03-12-2011, 09:30 AM   #4
I would echo SpecialK comments...
However, you already have quite a number of comments on each of the lenses in the Lens Review sectionFA 50/1.4 8.84F 50/1.4 9.6
... but it really comes down to what you like...
03-12-2011, 10:49 AM   #5
Pentaxor's Avatar
maybe you want to take a look at this >>> https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/136278-4-lens-50mm-shoot-out.html
03-12-2011, 11:17 AM   #6
axl
I voted for 50/1.7. Used to have the F version and haven't stopped regretting selling it since Jan 2010.
I think you'd end up the same....
03-12-2011, 01:18 PM   #7
RioRico's Avatar
My vote: the F50/1.4. The quality is very good. The speed can be crucial. It's just more flexible in usage than even the best f/1.7. That's my story, and I'm sticking with it.
03-12-2011, 05:39 PM   #8
A question nobody can answer without additional information.
Both your lenses are very rarely seen.
If you like bokeh, keep the F 1.4/50. It has 8 aperture blades. The 1.7/50 only has 6.
From f/2.8 and up the difference is very striking.
Need less field curvature, probably better edge sharpness (near) wide open?
Go for the 1.7/50.
Sell them both and get a A 1.2/50 instead? No idea what these things actually sell for. But it will be a lot.
03-12-2011, 05:42 PM   #9
Eruditass's Avatar
QuoteOriginally posted by Egg Salad Quote
Echoed.
Source?
03-12-2011, 06:27 PM   #10
paperbag846's Avatar
1.4 for sure. the 1.7 is a little sharper wide open but everywhere else the 1.4 looks better.
03-12-2011, 06:32 PM   #11
Pentaxor's Avatar
if he doesn't need AF, this would make sense.
03-13-2011, 10:48 AM   #12
G_Money's Avatar
While there is the case to be made that the F 1.4 has superior bokeh, I voted to keep the FA 1.7. If you ever yearn for an auto focus f/1.4 lens, one can easily be found. The auto focus f/1.7 lenses are harder to come by. I'll leave it to the more aesthetically minded to hammer out the bokeh issue. I guess I'm a member of the sharpness bourgeoisie that sees the f/1.7 50mm variants as the sweet spot. Like Axl, I once sold an f/1.7 50mm and I ended up buying three to replace it.
50mm, k-mount, lens, pentax lens, slr lens
Keep K-x buy premium lens, get K-r and get good lens, get the K-7 w/ lens or K-5? crossover37 Pentax DSLR Discussion 19 02-06-2011 10:38 PM
All times are GMT -7. The time now is 05:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
