I purchased a set of Asahi Bellowscope in M42 mount. It's a great vintage accessory, but it doesn't seem to work for my purposes. Maybe I'm just doing something wrong?
I was hoping to use it to block out side light and camera reflections when digitizing film (645 medium format film taped flat to a lightbox). I found that my camera and lens sometimes show up as reflections on the film "scans", especially in shadow areas on slides.
Anyway, with this bellows, I tried placing my Macro-Takumar 50mm lens on one end of it and my K-x DSLR on the other. But no matter what length I adjusted the bellows to - or what focusing distance I set on the lens - it was always way too close to the film and would fit 1/3rd of the area of the film negative at best.
I then tried mounting the lens directly on the camera again and placing the bellows in front. Of course that didn't work that well since the bellows has a 42mm diameter and the lens is 49mm, so it cuts off a big part of the field of view.
I wonder if extension rings would help my situation somehow? Or metal 49mm lens hoods if I could somehow stack a couple of them to get to 280mm length (that seems to be the minimum focusing distance with this lens that fits the whole piece of 645 film).
Or perhaps there's another type of bellows or some other light-tight attachment I can use? One that can screw in to 49mm filter thread on one end, have an opening big enough for 120 film on the other, and be adjustable to 280mm in length.
You can also read my older thread about this slide copy setup for background info.
