03-15-2011, 10:18 PM   #16
bwDraco's Avatar
Unless Klaus publishes a conversion factor, there is no way of figuring it out for now. The figures are rather arbitrary (depend on AA filter strength and heavily depend on the amount of sharpening used) so results across cameras are not transferrable.
If I'm not mistaken, sharpening should be consistent and the strength of the AA filter is reflected in the maximum LW/PH value of the image sensor.
--DragonLord
03-15-2011, 10:59 PM   #17
Chex's Avatar
I've been waiting on his review of the 18-135 so long I will already be shooting with it by the time it gets completed.
03-16-2011, 01:20 AM   #18
ogl
ogl's Avatar
QuoteOriginally posted by DragonLord Quote
I don't think you need to wait for Falk Lumo (falconeye).
Multiply the lens' resolution as measured on the K10D by 2750/2350, or 1.17. The 1.17 factor is the ratio of the maximum resolution of the K-5 compared to that of the K10D.
--DragonLord
+/- yes...FA43 is still the best.
03-16-2011, 01:20 AM   #19
ogl
ogl's Avatar
QuoteOriginally posted by Chex Quote
Klaus postponed this review because of bad copy of lens.
03-16-2011, 04:39 AM   #20
Quite true. Says so, right on the site. Probably the biggest thing that I look at is the aperture at which performance is peak (here, looks like f4) and the performance wide open in comparison.
Sharpness is generally overrated, since nearly all modern lenses are sharp. However, their rendering differs greatly.
03-16-2011, 04:57 AM   #21
bdery's Avatar
QuoteOriginally posted by ogl Quote
You can calculate the resolution of lenses at 16 MP if you know LW/PH at 10 MP.
You cannot assume that you can just convert one with the other, that would work only for a lens that didn't outresolve the K10D sensor. so basically it rules out every lens at their peak performance
03-16-2011, 05:22 AM   #22
bwDraco's Avatar
Thanks. I'm sorry if my post is erroneous; ogl and I were assuming that the MTF values were proportional. I certainly don't want to confuse readers of this forum...
--DragonLord
03-16-2011, 10:01 AM   #23
bdery's Avatar
Hey! No worries! That's one reason why Klaus says results cannot be compared with different systems. At least when the camera's resolution is similar, it doesn't create even more problems...
k-mount, pentax lens, review, slr lens
DA*60-250's review at photozone.de. ogl Pentax SLR Lens Discussion 18 01-11-2010 08:24 AM
DA 15mm Photozone Review!! K206 Pentax SLR Lens Discussion 2 10-19-2009 08:17 AM
photozone da35mm limited review is up! architorture Pentax SLR Lens Discussion 28 08-23-2008 07:38 AM
Photozone review DA* 50-135mm ZaphodB Pentax SLR Lens Discussion 12 10-15-2007 09:40 AM
All times are GMT -7. The time now is 02:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
