10-23-2007, 12:21 PM   #1
Green_Manelishi's Avatar
"Stuck" lens hood
Greetings one and all.
I recently purchased a Pentax K10D as my first dDSL and am very pleased so far with the camera.
However, after using/storing the lense hood several times I somehow managed to store the lens hood on the lens in such a manner that it cannot be removed. Now, I'll be the first to admit I can force many things into compliance but the hood went on incorrectly with no trouble. I've brought it to the POP and the suggestion was made that I break the lens hood off of the lense; I think I don't like that idea very much.
Has anyone else had this experience and if so how did you remove the lense hood without damaging it or the lense?
Thanks.
G_M
10-23-2007, 01:12 PM   #2
Try a couple of drops of vegetable oil around the ring of it.
Let it sit for a while, then try.
With a little luck this will lubricate the hood enough to allow it to slip off.
Be very careful where you put it, you don't want the oil to go where you don't want it.
I wouldn't try anything other than vegi oil.
10-23-2007, 02:12 PM   #3
roy
roy's Avatar
it's got to be bound up somewhere. try and find that point and try squeezing the hood to remove the pressure at that point. what have you got to loose.
10-23-2007, 03:05 PM   #4
Moderator Emeritus
You can also get one of those jar lid openers and that should give you enough leverage on the hood to unscrew it. Others have had the same issue with filters and this worked for me and them. I'd use any oil as a last resort.
10-25-2007, 06:33 PM   #5
problem solved
Another camera shop employee was able to remove the lense-hood and agreed there is a design flaw that allows the hood to be stored incorrectly, effectively locking it down.
hood, k-mount, lens, lense, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 33 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
"Stuck" in Belgium for a couple of days next week pingflood General Talk 5 10-28-2008 04:18 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 11:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
