03-22-2011, 07:47 AM   #16
sterretje's Avatar
QuoteOriginally posted by deadwolfbones Quote
28 is pretty damn narrow for an all-around on a crop-sensor camera.
That depends I use a FA31Ltd as my walk around
03-22-2011, 08:05 AM   #17
QuoteOriginally posted by sterretje Quote
Sure, and that works for some people. But the OP is looking for a zoom, presumably because he wants to as many shooting scenarios as possible with a single lens. I wouldn't want to rule out the wide-angle stuff.
03-22-2011, 08:53 AM   #18
Thanks a lot for all your opinions.
For wild angle I have DA15 that I really love. I need to cover FL between 15 and 43. One option was DA21, but I would really prefer zoom lens for this. I had never shoot with zoom lens, so yours suggestions are very helpful for me. Thanks a lot.
Best regards,
Yuriy
03-22-2011, 01:12 PM   #19
Jewelltrail's Avatar
QuoteOriginally posted by Chex Quote
I don't think I would be looking at the 17-50 when the 28-75 macro would probably be a better all around lens and can do double duty being able to shoot Macro. I'm sure after I get my 18-135 serviced it will be just fine. Having the WR lens to go on the K-5 for those wet days will be nice.
OP wants to do city & landscapes--I owned both Tamrons, & the 17-50 is far better range for this. Also, the 17-50 will close focus down to about 10" and does macro every bit as good as 28-75. Of course, neither lens is a Macro lens anyway.
yurko_yr: I am shooting mostly landscapes and cityscapes.
03-22-2011, 02:08 PM   #20
paperbag846's Avatar
Get the Tamron. You won't feel the need to replace it, or buy primes in that focal range. With the super-zoom, it's going to be weaker at the extreme ends, and slower. You might end up spending more money with fast primes and the like.
The Tamron goes up to 50. There are a tonne of consumer zooms (70-200 ish) that are as slow as the 18-135, but they go much longer. In conjunction, the 17-50 + 70 - 200 won't be much more expensive (if at all).
An example is the F 70-210, which is great. I think they are pretty common at 100 bucks. There are a lot of lenses in that range too, so it would not be hard to find a good deal.
When I have the funds, my kit lens is going to become the Tamron.
03-22-2011, 03:43 PM   #21
Thanks a lot. That is why I so like this forum. So many thing possible to learn from this community.
I think I will go for tamron lens. I have a telefoto covered and planning to buy few primes – 43 and 77. For wild angle DA15 is a miracle for me. I don’t think I will buy FA31 and do not want to buy DA35/2.4 as well as DA35 limited (had this lens – great one, but for some reason did not fit my sole). I am thinking to cover these FLs (20-40) with zoom. Tamron looks like the best option. I do not need an expensive zoom, because prefer primes. The only thing that bother me know is a QC of tamron lenses. I was thinking to buy from prodigital2000, but they have a tricky return policy, so probably BH or Adorama would be the best options. What would you tell?
03-22-2011, 03:48 PM   #22
QuoteOriginally posted by yurko_yr Quote
I would confirm with prodigital, if they are not going to be easy, then go with BH / Adorama.
You will likely have a good lens from the get go but it's not worth the risk for 50 bucks.
03-22-2011, 05:32 PM   #23
what about the sigma 17-70 (non OS) for a walk around lens?
It's seems cheap and has good reviews.
It'll have better IQ than 18-135 and a bot more range than 17-50.
Plus it's a macro lens
03-22-2011, 05:57 PM   #24
QuoteOriginally posted by oliver939 Quote
It's not a macro lens. It has "macro" capability, which for a zoom means it focuses down to 1:4 or 1:5, typically. The Tamron has this as well.
The Sigma has a variable aperture and costs just as much as the Tamron. 20mm on the long end really isn't that much, either.
I've owned all three lenses. There's nothing wrong with the Sigma--it's a fine lens for what it is--but the Tamron is better in every way except for tele reach.
03-22-2011, 09:47 PM   #25
SpecialK's Avatar
I tried the 28-75 as a single walk-around. I was backing up frequently, and running out of space. But, I like wide, and everyone is different.
03-26-2011, 07:55 PM   #26
Dear Pentax Community,
Thank you for all your advises. This forum is a great source of knowledge and information.
So, I got a Tamron 17-50/2.8 and it looks like I really like it. The colors a great and the feeling of the lens is also very nice. The focus is fast and to my feeling quiet. However I tested the lens mounted on tripod and it looks like the upper corners are soft. Could you please tell if this is my error or it is really soft and I should exchange this for another copy?
Thank you in advance.
With the best regards,
Yuriy
03-26-2011, 07:57 PM   #27
First picture – is center, second – upper left corner. Camera mounted on tripod, daylight, 35 mm, f 2.8.
03-27-2011, 12:33 AM   #28
Yuriy
Yuriy: I would be seriously skeptical about these results. When properly focused, I never got a real life shot with the 17-50 with anything but very good borders. @ f 2.8, this close on a tri-pod, DOF is so thin that you must have the test setup perfectly in order to have the corners of the shot in the same focus plane as the center of the image. Try shooting the lens in real life conditions, then look at the borders--they rival a prime. Have you seen Photozone's MTF scores on the lens?
03-27-2011, 01:09 AM   #29
It's field curvate - see Tamron AF 17-50mm f/2.8 SP XR Di II LD Aspherical [IF] (Nikon) - Review / Test Report - Analysis paragraph MTF.
03-27-2011, 06:16 AM   #30
Thanks a lot. I shoot some cityscapes today and corners looks sharp. It was my error during a test.
Thanks a lot for explanation.
Best regards,
Yuriy
k-mount, lens, lenses, pentax, pentax lens, slr lens, tamron
DA18-135 or DA18-250? jatrax Pentax SLR Lens Discussion 17 04-25-2011 08:41 PM
DA18-135 => Satisfied xGene Pentax SLR Lens Discussion 7 12-15-2010 02:17 PM
Tamron 17-50mm f2.8 worth the upgrade over DA18-55mm WR? secateurs Pentax SLR Lens Discussion 35 11-02-2010 12:37 PM
Pentax 55- 135 f2.8 Vs. Tamron 70 -200 f2.8 mikejustice Pentax SLR Lens Discussion 13 08-23-2009 09:27 AM
All times are GMT -7. The time now is 06:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
