Originally posted by Lowell Goudge Just one additional point about the new 10-20 over the old
I believe the F3.5 is constant over the entire range. The old is F4-5.6
While it is only a half stop at the wide end it is 1 1/2 stops at 20 mm
constant aperture is surely a good thing, so u almost dun hv to change any setting at all as u zoom in n out. but on uva lens the effect on f-stop would be minimal.
When u looking at f stop u hv to related that to the focal length too. The light gathering capacity is different on a 100mm 2.8 and a 28mm 2.8 lens. Its all depends on the aperture area and u hv to throw the focal length as a factor in that equation. Lets see the aperture area difference on a 20mm lens between f/5.6 and f/3.5; the area of aperture on f/3.5 is about
15 mm sq. more than f/5.6
mmmmmmmmmm , sounds like a lot
but when u look at the area difference between a 100mm lens on f/5.6 and f/3.5 is 390mm sq.
difference of a 300mm lens is 3500mm sq.
a 500mm lens has a difference of 9700mm sq. !
so what it means is the f stop difference on a shorter lens would have less effect than when you r comparing the longer lens.
since for uva is the widest lens u can get, the f-stop factor is not as big as when u look at the other lens.After all these calculation, i walked out of this miserable situation for deciding what uva lens to buy and ended up with the" slower but doesn't reli matter" Sigma 8-16.
but yeah, i have been trapped in there before, not until the painful process of going to the library to read books about the physics.
* but still, my opinion is still objective and i know that well lol :P
