04-01-2011, 05:19 PM   #1
Loren E's Avatar
DA* 60-250mm light grinding noise?
When I point my DA* 60-250 down with the lens cap on and let it hunt back and forth on AF it has the same uniform sound, but when I point it upwards, when going towards infinity it makes a funny sound while hunting, almost like the slightest grinding sound. Grinding might be a bit of a strong word, maybe it is something making small vibrations, but it is a clear sound not present when the lens is pointed down instead of up. It focuses fine by the way as far as I can tell in normal situations, but the sound has me concerned.
Has anyone else experienced this? Should I be worried/post a video of the sound?
Thanks! -LE
04-03-2011, 06:53 AM   #2
Loren,
I checked out my 60-250 for you. It makes pretty much the same noise when pointed either up or down.
My DA*300 made a squeaky sound when I first got it but it is quiet now. I guess there is a little break in period.
regards
04-03-2011, 01:22 PM   #3
Loren E's Avatar
Much appreciated Gary, I checked my 16-50 and it does the same though not nearly as loud as the 60-250
da*, k-mount, lens, pentax lens, slr lens, sound
Pentax-F 50/1.7 grinding noises while focusing Eruditass Pentax SLR Lens Discussion 16 02-17-2013 10:30 PM
Does your sensor make a grinding noise? Gilzuma Pentax K-r 9 03-29-2011 05:51 PM
K20D grinding noise on turn-on ??!! mrpink Troubleshooting and Beginner Help 4 09-06-2009 07:20 PM
Pentax 18-250mm... Kitty in low light lapeen Post Your Photos! 4 02-21-2008 04:06 PM
Low light and noise Substitute Photographic Technique 11 11-09-2007 10:31 AM
All times are GMT -7. The time now is 02:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
