04-02-2011, 02:10 AM   #1
flare-resistent wide angle lens needed
Hi
I have the Sigma miniwide 28mm f2,8 (old version) and love the angle of view, could use a little more sometimes though, but in sunlight it just shows the ugliest flare, and all contrast is lost.
I need more resistance than a hood alone can provide
So I need a cheap (max $100 approx.) wideangle with good flareresistence (like the famed 15 ltd.)
So what would you suggest? and if you have pics to backup your choices, I would be delighted.
some ex of the flare both with and without the sun in the frame both stopped down to f11 or smaller
04-02-2011, 02:38 PM   #2
bump
Heiberg,
My suggestion would've been the DA 18-55, but I see you have one already. Have you tried using a deeper hood on your Sigma?
Tim
04-02-2011, 03:00 PM   #3
Nesster's Avatar
If you are willing to look at manual focus, and especially if you already have the adptall, the Tamron 24/2.5 is very flare resistant. Another good one in manual focus is the SMC-A 28/2.8. Probably the Tamron 28 as well.
In autofocus, I don't have a clue!
04-02-2011, 11:51 PM   #4
Thanks
Autofocus isn't really important, but being a prime is.
I don't own anything adaptall, but that shouldn't prevent me from the tamron 24, sounds interesting.
What I forgot to mention, is that size matters, so a deep hood would be a little annoying.
04-03-2011, 05:29 AM   #5
acrollet's Avatar
I own an old vivitar 28/2, and have found that flare resistance is quite decent. It's not like the da15, which is darn near flare proof, but it's quite a bit better than the samples you posted in my experience. Only problem with the vivi 28s is that there are many different versions, check out robin parmar's bestiary - I have the A01 version fwiw...
04-08-2011, 02:21 PM   #6
macTak's Avatar
Yes, those wide Sigma's do tend to flare easily (I have the 24mm, and its only real drawback it flare if you aren't careful). If you want a little wider lens, you'd be looking at the 24mm focal length, and I can't really think of any third party lenses noted for their excellent flare resistance in this FL. I think the Pentax-K 24mm f2.8 is supposed to be pretty good against flare, certainly better than the Sigma equivalent. For a 28mm lens, I can highly recommend the Pentax-M 28mm f3.5--very sharp, contrasty, and quite flare resistant. You can easily get one for under a hundred shipped.
04-08-2011, 11:17 PM   #7
Thanks macTak, The 28, f3,5 is added to my list
04-08-2011, 11:36 PM   #8
paperbag846's Avatar
QuoteOriginally posted by Nesster Quote
SMC-A 28/2.8
This lens flares pretty badly IMHO.
Great lens but I think the kit lens is a better performer as far as flares go.
04-09-2011, 07:27 AM   #9
reeftool's Avatar
Flare is a problem with my DA 18-55. Trying to find a lens with the flare properties of a DA 15 for under $100 won't be easy. Actually, I don't think there are many lenses at all that handle flare like a DA 15.
angle, angle lens, flare, k-mount, pentax lens, slr lens
Info on Lenses needed - F2.8 120mm, F3.5 28 mm wide angle Pentax, etc. SweetSherri Pentax SLR Lens Discussion 19 07-19-2010 09:13 PM
Best wide angle lens A.M.92 Pentax SLR Lens Discussion 8 06-29-2010 02:21 PM
Wide-angle lens for K-7 windflower Troubleshooting and Beginner Help 10 11-27-2009 03:05 AM
advise needed:wide-angle lens Slice Pentax SLR Lens Discussion 4 11-09-2009 10:22 AM
Wide Angle Needed Slick Pentax SLR Lens Discussion 11 02-04-2009 01:30 PM
All times are GMT -7. The time now is 03:40 AM. | See also: NikonForums.com, part of our network of photo forums!
