04-04-2011, 04:51 AM   #1
Removing the front ring of the 50mm 1.7 Auto Chinon
Well met!
I have a manual 50mm 1.7 lens that had dust and sand in it thus i decided to clean it up whilst waiting for my k-r to arrive
While not having any experience (it's the first lens i open up and clean) i decided to make a new post to show what was the most tricky part of the whole process from the novice's point of view:
Removing the front ring, opening up the way to the front lens element.
Also here on the Pentax forums there is a tutorial/discussion on this procedure with a 50mm 1.7 manual lens (https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/136247-cleanin...mm-f1-7-a.html). Thanks again guys!
I won't go into the details on how to disassemble and unscrew everything, you'll manage this by yourselves. As i said, for me the trickiest part was removing the front ring, mostly because i didn't know/visualize until finally getting it off how thick it is.
The orange tool (spray cap) was inspired from a video on youtube fellow pentaxian glee46 linked in another post:
, or search on youtube for: PENTAX-M 1:1.4 50mm Cleaning.
But enough talk, here are the images:
Will update with any worthy info in the future. At the moment waiting for the light grease for the focusing ring to arrive.
Best wishes!
04-04-2011, 06:13 AM   #2
boriscleto's Avatar
Lens Ring Tool Kit, Gum Rubber 10 Pc.
05-23-2011, 02:54 AM   #3
Has anyone worked on the front elements in the earlier non-mc version of this lens...?
I have a nice 55/1.7 Auto Chinon and I have removed the front ring and extracted the front element cluster but I cannot seperate the front elements from each other.
I have tried a compass-type tool in the two small holes at the back of the front elements but it won't budge...maybe it's glued...any suggestions on a safe glue solvent to try...?
Many thanks
05-23-2011, 05:21 AM   #4
boriscleto's Avatar
The lens elements of most early lenses were glued together with Canada balsam. To separate them, put it in a pan and cover it with water. Then bring the water to a boil. The boiling action alone will probably separate the elements after a few minutes.
05-25-2011, 01:30 AM   #5
Thanks for the suggestion but the lens group is designed to unscrew I think.
There is a blob of clear (nail?) varnish locking a section - what is safe to use for softening the varnish lock...will nail varnish remover damage lens elements...?
50mm, front, k-mount, lens, pentax lens, pentax-m, post, slr lens, youtube
auto chinon 1:1.9 50mm prime lens lely7 Pentax SLR Lens Discussion 6 09-20-2011 06:33 AM
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
For Sale - Sold: Auto Chinon 50mm 1:1.9 K-mount Lens (US) ConstIva Sold Items 5 02-06-2011 03:46 PM
Auto Chinon 50mm f/1.9 Ehlacore Pentax SLR Lens Discussion 6 12-04-2010 04:45 AM
For Sale - Sold: Auto Chinon 50mm f1.9 Manual Lens pentaman Sold Items 5 12-21-2009 03:10 PM
All times are GMT -7. The time now is 03:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
