08-15-2011, 05:26 PM   #16
QuoteOriginally posted by Spodeworld Quote
So, the foil is for CIF, not if you want to just use it for manual focusing in M or A modes....do I have that correct?
Thanks
No. I meant that a conductive base is required for CIF. Perhaps you can find other ways to get correct exposure for non-conductive base lenses. I haven't found anything easier.
08-15-2011, 06:13 PM   #17
Spodeworld's Avatar
I've heard something about using a green button when in M mode to set the shutter speed. I heard nothing about using foil in that case. So, I was under the impression that you can meter in M mode after setting the aperture using the magical green button and no foil.....i guess once my K20D arrives I'll get a shot at trying it out and hopefully it will start to make more sense (after I get fully confused).
08-15-2011, 07:59 PM   #18
jatrax's Avatar
Here is the sticky dealing with using older lenses with Pentax DSLRs.
In short, you may use the M mode and the green button (assuming it is configured correctly) to set the shutter speed. This takes one extra step but is the most consistent. You can also use Av mode and depending on the lens and camera combination it may work correctly or it may be off by as much as 2 stops. If I am going to use Av mode I take a few test shots, adjust the exposure compensation dial to suit and then don't worry about it. Unfortunately the effect is not consistent across apertures so if you are changing the aperture dramatically you may still find it somewhat inaccurate. Again, depending on lens and camera. It is reported by some that they get more consistent readings in Av mode by using foil to short the contacts. I tried this and found no significant difference on my lenses and camera. YMMV.
The foil is required if you want to use catch in focus. It is needed to tell the camera that there is a lens attached. Note it does not have to be foil, only a conductive base. Many lenses already have this, you need to foil the ones that are painted black.
08-15-2011, 10:45 PM   #19
...and not even all of those. My Jupiter-9 85/2 has conductive paint...go figure. Strangely enough, this causes a problem in that sometimes the lens is detected as having "A" contacts. Not good, since the data is never correct.
08-16-2011, 05:26 AM   #20
Spodeworld's Avatar
Thanks guys. This was helpful for getting a basic understanding of using a manual lens, or at least a starting point for M42s. My K20D should be arriving today, so I'll have a chance to test this out. At this point I only have M42 lenses to use on the Pentax. I got the camera because M42s don't work well with my Nikon, and my infinity adapter doesn't seem to allow infinity focus!
Now, I need to start learning about all these different types of Pentax lenses and lenses that one can use on their Pentax DSLR. It seems daunting!
k-mount, pentax lens, slr lens
For Sale - Sold: m42 Tele-Takumar 300mm F6.3 and GENUINE Pentax m42-to-K adapter (US/CAN) LowVoltage Sold Items 5 03-22-2011 05:55 PM
For Sale - Sold: Gruppo Manfrotto 3 section aluminium monopod 434B (Worldwide) samski_1 Sold Items 0 03-06-2011 04:01 AM
For Sale - Sold: Tamron 300mm 5.6 m42, Sears 200mm 3.5 m42 mount. telfish Sold Items 13 02-28-2010 10:30 AM
For Sale - Sold: Industar 50-2 50mm f/3.5 Soviet M42 lens + M42 Adapter 65535 Sold Items 10 11-27-2009 04:18 PM
For Sale - Sold: M42 Tair 11-A (135mm, F2.8), Genuine Pentax M42 to K adapter PrimeObjectif Sold Items 15 11-02-2009 07:20 PM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
