04-05-2011, 02:50 PM   #1
When do you use aluminium foil on M42?
I don't understand when you know to use tinfoil on the lens to short out pins (or something like that). I don't want to tear up my camera. Can anyone comment?
04-05-2011, 02:52 PM   #2
I think, and could be wrong, that if you want to use Catch In Focus, would be about the only time for doing so. I've never found any issues with not using foil in any other case (I've never foiled my lenses).
04-05-2011, 02:57 PM   #3
dadipentak's Avatar
I had to use foil to get the AF 1.7x TC to work with my screw-mount Tak.
04-05-2011, 03:06 PM   #4
aleonx3's Avatar
I do it for catch-in-focus when I use MF lenses including m42 and K-mount.
04-05-2011, 03:27 PM   #5
selar's Avatar
QuoteOriginally posted by dadipentak Quote
Ditto
04-05-2011, 03:28 PM   #6
Lowell Goudge's Avatar
I think it depends on camera and lens. Some cameras don't give focus confirmation without the 7th pin of the lens shorted to the mount It's really too bad pentax can't give a menu setting to correct this
04-05-2011, 04:08 PM   #7
Lloydy's Avatar
Find a heating engineer and get a bit of the sticky aluminium tape that they use inside boilers, it's stronger and the sticky holds it in place.
It's way better than cooking foil.
There's a picture of my Helios somewhere on a catch in focus thread on this forum showing the foil tape, but I scratched the paint off in the end as it's a cheap lens and the foil tape eventually came off.
04-05-2011, 04:40 PM   #8
wasser's Avatar
I also use it on my Km to get proper exposure in Av mode. Wiithout it it's consistently 2 stops off.
04-05-2011, 06:05 PM   #9
RioRico's Avatar
Rolls of metal duct tape (not the plasticky DuckTape sort) are quite inexpensive. My roll of Nashua tape, maybe 50 feet, cost under four bucks at a non-discount hardware store in a pricey resort town. Even with my hundreds of lenses, it's enough for several lifetimes. Cut a strip about 1/4 inch | 6.5mm wide. Then cut that in half lengthwise. Note where the lens base covers the contacts. Stick the tape there. VOILA!! Another lens converted to CIF!
I use the tape on any screwmount lens with a base wide enough to cover the contacts. Most 3rd-party K-mount lenses have steel bases that short the contacts nicely. A few K-mount lenses, and more than a few cheap K-mount macro tubes and thread-reversal rings, are painted black and thus don't short the contacts. DO NOT APPLY TAPE TO K-MOUNT BASES!! The slight thickness of the tape will cause the base to jam onto the camera!! Instead, use a file or sandpaper to scrape off the paint in the appropriate place.
08-15-2011, 02:14 PM   #10
Spodeworld's Avatar
A little confused
I'm brand new to Pentax (been using Nikon, but decided to pick up a K20D for the M42 lenses since Nikons don't focus to infinity with them, even with the infinity adapters!). I'm expecting my K20D to arrive tomorrow, and am looking forward to it.
So, is the tin foil just used for the Catch in Focus functionality? And, someone mentioned they use the tin foil "on my Km to get proper exposure in Av mode. Wiithout it it's consistently 2 stops off." Why would the use of tin foil have any bearing on metering, or did I read the intent incorrectly?
Thanks
08-15-2011, 03:31 PM   #11
foil for flash
QuoteOriginally posted by Spodeworld Quote
Not entirely. If you short out the recessed "A" pin on the camera, auto flash will work. Try turning the e-wheel to lowest f-stop & setting whatever f-stop you like on the lens.
It is a mystery. but without the foil the camera has no way of even knowing there is a lens on it.
08-15-2011, 04:14 PM   #12
Spodeworld's Avatar
But, even without the foil, doesn't it meter in M and A modes? I thought it did, it's just that it doesn't know what the aperture is. Is that correct?
08-15-2011, 04:21 PM   #13
Could be, maybe you can reverse software engineer it & guess at why it behaves the way it does. In the end it is likely easier to short a contact. You'll need to do that anyhow to get CIF to work.
08-15-2011, 04:22 PM   #14
08-15-2011, 05:09 PM   #15
Spodeworld's Avatar
So, the foil is for CIF, not if you want to just use it for manual focusing in M or A modes....do I have that correct?
Thanks
QuoteOriginally posted by newarts Quote
k-mount, pentax lens, slr lens
For Sale - Sold: m42 Tele-Takumar 300mm F6.3 and GENUINE Pentax m42-to-K adapter (US/CAN) LowVoltage Sold Items 5 03-22-2011 05:55 PM
For Sale - Sold: Gruppo Manfrotto 3 section aluminium monopod 434B (Worldwide) samski_1 Sold Items 0 03-06-2011 04:01 AM
For Sale - Sold: Tamron 300mm 5.6 m42, Sears 200mm 3.5 m42 mount. telfish Sold Items 13 02-28-2010 10:30 AM
For Sale - Sold: Industar 50-2 50mm f/3.5 Soviet M42 lens + M42 Adapter 65535 Sold Items 10 11-27-2009 04:18 PM
For Sale - Sold: M42 Tair 11-A (135mm, F2.8), Genuine Pentax M42 to K adapter PrimeObjectif Sold Items 15 11-02-2009 07:20 PM
All times are GMT -7. The time now is 11:43 AM. | See also: NikonForums.com, part of our network of photo forums!
