I have seen copies which are very, very poor in the corners--disgraceful actually---but those are obvious. This one is not bad. Shooting perfectly flat subjects is silly & proves nothing: reality is not two-dimensional, yet forum member after member continue to judge their lens based on non-reality.
Moreover, some lenses are very sharp to the corners, but have field curvatures--this means shots of perfectly flat subjects will make the lens look bad, even though lens is good. A field curvature often has no bearing on real life shots. Shooting reality is about 3 dimensions, so this is where you take test shots. Photozone goes as far as to say that probably no lens is technically perfect, that they all have a centering problem to one degree or another. People are hung up on perfection, though God knows why because none of us are perfect.
As others have said, take real life shots, and ask yourself if you are happy--you spend the money--you are the judge. If you bought from a good dealer, exchanging for another will not be a problem. Worst thing you can do, is be unhappy with the lens & hang onto it out of uncertainty: make a decision which makes you happy. Either try another lens, or return for your money back.
EDIT:
Quote: Pentaxor: if you are unhappy with it's performance at wider openings, get the Pentax DA12-24.
The Sigma Ultra wide angle choices are also excellent, should you decide the Tamron is not what you want. Lots of pics in the Sigma 10-20 & 8-16 Clubs if you need them. Good luck!
