Slow Diaphragm Blades on K 28mm f3.5
Hey guys, the diaphragm blades on my K28 f3.5 are a bit slow. I took the mount off to see what's the matter, and to me it seems like the ring with the aperture lever is rubbing again the mount at some point. When I take off the mount everything seems to be pretty good. I've read somewhere recently that K series lenses tend to develop this problem, so I was wondering if any of you've guys found a way to solve this issue.
I tried applying some lube, which didn't seem to help. Also tightened all the screws to make sure they don't stick out. The lens now works much better than when I bought it, like I couldn't even use it at f8 because the blades were too slow. But I think I can now crank it up all the way to f16. However, f22 seems to be a bit too slow. I don't want to start sanding things off just yet to make sure I don't mess it up. Any tips? Thanks.
