Originally posted by feilb What other manual lenses? The only lenses this won't be a problem on are auto aperture lenses like the pentax a series or "preset" lenses like the Jupiter 9 (which have one aperture ring to set the aperture and a second to quickly switch between wide open and the aperture "preset" with the other).
The problem does not happen with pentax K and M series manual lenses. I have used 28mm and 55mm K lenses and 50mm and 85mm M lenses with no issues.
Originally posted by taurus9 This is the normal behaviour for adapted lenses, including the Leica R's. It is stop-down metering only in this case since the aperture lever in the R mount lens is not controlled in Pentax cameras. The only cameras that accept R-mount lenses without having to perform stop-down metering are ... the Leica R series cameras.
If you're talking about manual lenses in general, Pentax M and K mount lenses do not require stop-down metering because the green button does that for you.
If possible, focus first, stop down to meter and then shoot. It is a part of the workflow when one uses adapted lenses, but I guess one plus is permanent depth of field preview...
Thanks taurus9, that clears it up. Reputation point added
