04-06-2011, 08:57 PM   #1
Can anyone tell me what this ring on Tamron lens is?
I just bought a new Tamron zoom lens for pentax online. When I opened the box, the lens looked in good condition, but there was a coin size black ring slipped off when I opened the lens back cover. See the photos. When I checked the ring carefully, there was a tooth( a small tab) was broken on the edge of the ring.
Without this ring, my pentax kx works normal when the tamron lens mounted. At least I don't see anything wrong at first dozens shoots.
Can anyone tell me what this ring is? Is my lens good copy? thanks
04-06-2011, 09:20 PM   #2
gebco's Avatar
This is what my Tamron 17-50 looks like. Perhaps it is the inner ring seen around the rear lens element here?
04-06-2011, 09:40 PM   #3
QuoteOriginally posted by gebco Quote
Thanks. It looks like a inner ring you said. What's the function of inner ring? What will happen if without inner ring? I shot some test photos, although I didn't feel difference, I guess the ring is necessary otherwise Tamron doesn't place it there. Does anyone know?
04-06-2011, 09:47 PM   #4
ponyt27's Avatar
QuoteOriginally posted by looktime Quote
The ring might be just a protector for the rear mount during shipping??? If you have concerns give Tamron an email with pic of the ring....I`m sure they can advise you..
best of luck!
04-07-2011, 01:43 AM   #5
shiner's Avatar
That's strange. Nothing like that came with mine.
04-07-2011, 04:51 AM   #6
dadipentak's Avatar
Clearly you should consult Tamron. From the look of it I'd say it might serve as a "light sponge" to prevent stray reflection off the metal elements. Does it fit into the rear of the lens?
k-mount, lens, pentax, pentax lens, slr lens, tamron, tamron lens
Tamron 28-75 zoom ring?? COULDBE2 Pentax SLR Lens Discussion 8 03-25-2011 11:30 AM
Tamron 90mm macro plus pentax ring flash af160 MikeOz Troubleshooting and Beginner Help 3 10-09-2010 08:09 PM
Tamron 17-50mm/2.8 Loose Filter Ring? Venturi Pentax SLR Lens Discussion 4 06-18-2010 06:57 AM
Macro Trying out my new Tamron SP AF 90mm F2.8 and Pentax AF160FC ring flash nirudha Post Your Photos! 5 05-25-2010 10:46 PM
Liquid on lens outer ring jasonbx Troubleshooting and Beginner Help 3 01-24-2010 11:54 AM
All times are GMT -7. The time now is 11:52 AM. | See also: NikonForums.com, part of our network of photo forums!
