10-28-2007, 11:34 PM   #1
50-135 vs 43 vs 77
im debating between the 50-135 da* and the 43mm and 77mm limited lenses. i like the 50-135 because its versitile but how does the quaility compare to the limited models. im just not sure.
10-28-2007, 11:59 PM   #2
and
Its an interesting question. I have thought about this myself.
More specifically I was interested in how the 50-135 compares to the FA 50-77-100-135 lineup that coves the same range.
I belive the general conclusion is as usual that the primes are better, but the question, as always, is how much better, if we ignore the speed advantages of the 43/50 and 77 and compare from f2.8 and up. Certainly the 50-135 is very good. It is a fact that it does perform less at the long end, so it is better equipped to fight with the FA 50 than with the FA 135.
One thing I was interested in though, the 50-135 is supposedly a Portrait Zoom. indeed it covers the portrait range. Portrait lenses normally have slightly different characteristics than other lenses, such as being softer in the corners, or in general having nice rendering for portraits. The Fa 77 and Fa 85 are superb portrait lenses. I havent seen a lot of portraits from the 50-135 yet, and by that I mean real portraits, not snapshots of people. If I got one myself then portraits would be what I would use it for.
Back to your question. I think if you like the versality of the 50-135 then just go for it, its also weather sealed and has SDM which are added benefits and you dont have to change lenses. Surely it should be good eanough for all but the most critical.
10-29-2007, 02:27 PM   #3
thanks alot i think ill go with the 50-135 for now and maybe the 77 limited later on down the line. i was just looking for a good lens that is versitile and wont have to be changed frequently at a wedding or event.
im, k-mount, pentax lens, slr lens, vs
Chinon 135 & Chinar 135 , Good Bad or Ugly seacapt Pentax SLR Lens Discussion 1 02-26-2010 09:03 PM
shoot out DA*50-135 v.s. A50 A*85 A100 A*135 Douglas_of_Sweden Pentax SLR Lens Discussion 42 12-11-2008 10:44 AM
All times are GMT -7. The time now is 12:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
