Originally posted by baw
The K mount on your K110D does work with auto aperture and autofocus. Just see how the kit lens operates.
If you decide to use a lens that has no autofocus or auto aperture then these functions won't work off course.
Just to be clear, a K mount does not have automatic apature hence it can't work on any DSLR.
The kit lens is a KAF* mount, The KA mount was the first lens with automatic apature,
The K mount must be used in aither Apature priority mode where the camera will shoot at maximum apature and adjust shutter to make exposure correct, or in manual mode, where you basically set the shutter speed manually for the apature you have set, after metering in stopped down mode
