04-21-2011, 05:08 AM   #121
dgaies's Avatar
QuoteOriginally posted by Spotmatic Quote
Maybe the PZ review will cause the price to drop?
It's quite possible
I got my 18-135 pretty cheap (around $300 when all was said and done), so as I've said in previous posts, perhaps my expectations are lower as a result.
04-21-2011, 05:32 AM   #122
Thanks... Hm.. It looks like his 18-135 is sharper at 135 mm than 18-250...
As for me I found my 18-135 quite unusable at 100 mm and above...
04-21-2011, 06:16 AM   #123
audiobomber's Avatar
QuoteOriginally posted by frogfoot Quote
One has to wonder if this is a Pentax quality control issue.
04-21-2011, 06:57 AM   #124
I was never enthusiast about this lens. They should have tested at same resolution to compare MTF against other lenses.
04-21-2011, 07:13 AM   #125
QuoteOriginally posted by yusuf Quote
You don't think every company does this for every lens they make?
04-21-2011, 07:40 AM   #126
GeneV's Avatar
QuoteOriginally posted by audiobomber Quote
QC is quite possibly an issue, but different people have different definitions of "unusable" as well. I've heard people call the kit lens unusable, and I find it quite handy in many situations.
04-21-2011, 08:36 AM   #127
My 18-135 has better sharpness than my 18-250 in the center and across the frame, at 18mm and 135mm. I only tested wide open because the gap disappears as the apertures close.
https://picasaweb.google.com/bonhommed/18135Vs18250#
I haven't tried 18mm against a brick wall but in landscape test-shots the borders with my 18-135 at 18mm f3.5 were much softer than I see on your samples. The field curvature thing could explain that it's not to the same degree in every scene.
I'll believe a 50-200 is sharper when I see it confirmed. Sharpness is not comparable on the PZ tests due to different bodies, and I strongly suspect the lens used was substandard (not Klaus' fault).
Above 75mm my DA50-200 performs better in every way than my 18-135 except for autofocus. But it all depends on what copy you get I suppose.
I've posted a 100% crop here on the other forum:
big 100% crop: Pentax SLR Talk Forum: Digital Photography Review
04-21-2011, 09:14 AM   #128
Eruditass's Avatar
I think with consumer lenses, quality varies pretty widely, often greater than average performance between different lens models, with the minimum bar set rather low. Stellar performers are often not really supposed to be stellar, luck just granted them a good one.
04-21-2011, 09:15 AM   #129
QuoteOriginally posted by deadwolfbones Quote
Sorry I didn't get that, I was just suggesting that photozone should have tested it as same resolution (10MP instead of 16MP) so that comparison with other lenses was easier.
04-21-2011, 09:34 AM   #130
Very sad that many people rely and trust so hard on the PZ test when its still possible that the lens Klaus tested was a dud.
I stated somewhere else that Pentax is in fact known for sending back faulty lenses some times. Its called "within factory specs" and i have personaly seen this happen with a DA 40 Ltd and a DA* 50-135.
They do lab tests at given points but if the lens produce faults outside of that..... well there is the "within factory specs" excuse. They still can provide test resuts that prove the lens to be correct, in the area they test the lens.
Still.... i can not prove the PZ wrong, and i cant convince anyone. Just saying what i have experienced myself.
04-21-2011, 10:23 AM   #131
QuoteOriginally posted by GeneV Quote
This is what I call unusable. Comparison between 18-135 and 50-200: 100% crop of right lower corner.
BTW at wide to middle range my 18-135 is noticeably sharper and more contrast than 16-45 (I'm talking about center. Corners are still weaker). So I don't know if my lens can be called faulty.
P.S. After more careful examination I can say that 18-135 is not worse than 50-200 in the range of 50-100 mm.
PENTAX K-7  Photo
04-21-2011, 10:28 AM   #132
Ah, sorry. I thought you were talking about a different "they."
04-21-2011, 10:41 AM   #133
Senior Moderator
Parallax's Avatar
frogfoot, the 18-135 shot looks to me like motion blur, not focus or "softness".
04-21-2011, 10:49 AM   #134
QuoteOriginally posted by Parallax Quote
It can't be motion blur. The picture was taken at 1/200 s and using a tripod. The center of the image has no such doubled edges.
04-21-2011, 10:50 AM   #135
Senior Moderator
Parallax's Avatar
Was SR off?
k-mount, pentax lens, slr lens
I don't understand photozone.de justtakingpics Pentax SLR Lens Discussion 15 04-16-2011 12:20 PM
K5 and photozone bluekorn Troubleshooting and Beginner Help 5 02-02-2011 02:15 AM
DA*55 at photozone.de. ogl Pentax SLR Lens Discussion 6 11-24-2009 09:51 AM
DA 15mm at photozone Andi Lo Pentax News and Rumors 33 10-23-2009 02:22 AM
DA 15mm Photozone Review!! K206 Pentax SLR Lens Discussion 2 10-19-2009 08:17 AM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
