Hello all.
I am the proud owner of a K-7 with standard 18-55mm kit lens. However, I am already finding the quality/speed of the standard lens a little uninspiring, and also find myself in the fortunate position of having family that want to put some money towards a new lens for me as a birthday treat.
To that end, I am looking to purchase two primes; one in the "standard" range, and another in the "telephoto" range. So far, after much reading on these incredibly helpful forums, I've narrowed my selection down to two or three lenses in each.
Standard Lenses (in order of interest) SMC-Pentax-DA-40mm-F2.8-Limited ~ $360
SMC-Pentax-DA-35mm-F2.8-Limited-Macro ~ $540
SMC-Pentax-DA-Star-55mm-F1.4-SDM ~ $640
Three very different lenses, I grant you, and I am sure each is a keeper in its own right. However, I can only buy one to meet my "standard" prime need right now, and so I am seeking advice, guidance or just downright bullying as to which lens I should start with -- particularly given my K-7 body. The primary goals for this lens are sharpness, speed and simplicity; a lens to leave on the camera for all but formal portraits and long-distance work. In particular, I want a lens that will excel at landscapes, capturing crisp details and true-to-life color with minimal effort.
Telephoto Lenses (in order of interest) SMC-Pentax-DA-Star-200mm-F2.8-SDM ~ $960
SMC-Pentax-DA-Star-300mm-F4-SDM ~ $1400
I read both sets of reviews on this forum, as well as a number of other independent reviews, and of course I fell in love with both of these lenses, instantly. They are both as expensive as cars I have owned, and in parts of New Hampshire and Vermont, I could almost own land for this sort of money. But still, as Pentax primes go, these two seem to be "the bomb".
As with the "standard" lenses above, what I am looking for again here is, advice, guidance and/or bullying into which lens to buy. Both will be fantastic, but one will likely suit my needs better in the short to medium term. Currently, I am thinking the 200mm will be my best bet. Not only is it $400 cheaper, I suspect that given my relative novice status, the 200mm FL will be a little easier to handle and frame a meaningful shot. I am not likely to be doing any "sport" work with the lens, but I will be looking to sit at the local reservoir and capture some of the bird-life at work (heron, pelican, osprey, cormorant).
Side-note
I *could* be swayed into buying a non-Pentax glass, particularly if the price/performance ratio is significantly better and warrants due consideration. I could also be talked into buying just one, or even none of the above lenses; particularly if you could convince me as to why I should experience one before the other and perhaps wait to make a choice on the second.
Picking two of the lenses above will cost somewhere between $1,300 and $2,100; I would truly welcome some advice from those of you that have already had to make such choices or perhaps already own one of more of these lenses.
Many thanks in advance!
