04-19-2011, 09:18 PM   #1
BobDoLe's Avatar
is this haze?
i tried searching around for pictures of haze, but i was not successful in determining what this is.
i noticed my 50mm 1.4 was not as sharp as my 50mm 1.7 and happened to do the flashlight test. my 1.7 looked fantastic, but my 1.4 reflected a bit of what i think is probably a LOT of dust, but could be haze or maybe fugus?
i have a crop of the best shot i could get of it. then some with the light hitting it from different angles. looking at it head on, it looks pretty clear and i thought it was in perfect condition until i brought out an LED light...
04-19-2011, 09:24 PM   #2
whatever it is, it doesn't look like a good sign
04-19-2011, 09:50 PM   #3
selar's Avatar
Separation.
04-19-2011, 10:41 PM   #4
pbo
pbo's Avatar
+1 separation
04-19-2011, 10:50 PM   #5
selar's Avatar
+2 separation from the lens, as in you should part ways.
04-19-2011, 10:58 PM   #6
It seems to be on the front element.
And the front element is not cemented (http://kmp.bdimitrov.de/lenses/primes/_optics/50f1.4-ii.jpg ) so it seems more like haze or fungus.
Anyway untill you find the answer you should not store it with your other lenses !
04-20-2011, 12:28 AM   #7
BobDoLe's Avatar
i was looking at it from a few different angles and it definitely looks like its in there about 3 pieces of glass back. it seems to have a definite curvature to it and makes sense that it is separation
the diagram helps.
this lens has been in quarantine (about 20miles away on a shelf) since i discovered this as i didn't want to risk it. the rest of my lenses sit with silica gel. however, looking at pictures i've taken with it, even though it is slightly less sharp than my A 1.7, i do like the pictures it takes.
i guess i'll take a few more test shots and retire it unless it convinces me otherwise.
i've updated the serial database to reflect its condition.
thanks!
04-20-2011, 12:57 AM   #8
Ok sorry for you
But if it's not affecting too much the quality of the pictures then you avoided the worst...
04-20-2011, 06:28 AM   #9
eddie1960's Avatar
separation, but it's surprising how bad a lens has to be before it becomes unusable. it may now be prone to more flare or softness but i bet it still takes good images in many cases. I have seen images shot with cracked front elements that looked good
50mm, haze, k-mount, pentax lens, slr lens
Fungus or Haze on lens RollsUp Troubleshooting and Beginner Help 11 03-28-2011 05:29 PM
Travel Sunset thru the wine haze charliezap Post Your Photos! 5 03-21-2010 06:50 AM
Filters UV vs Haze 1 jonnyp Troubleshooting and Beginner Help 2 12-01-2009 04:20 PM
purple haze? what could be the cause JimD_K10D Troubleshooting and Beginner Help 18 10-10-2009 06:54 AM
Is there an easy way to fix haze in Photoshop? Hannican Digital Processing, Software, and Printing 22 06-01-2009 10:15 PM
All times are GMT -7. The time now is 08:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
