04-26-2011, 06:32 PM   #31
Lowell Goudge's Avatar
QuoteOriginally posted by justtakingpics Quote
I don't know which one I have but was only meaning up to 2.8. I don't know if I need the extra 2 stops.
If you don't know what you need it is really hard to tell you which will serve you better
04-27-2011, 07:17 AM   #32
alper's Avatar
Just to be clear, there are many many pentax 50mmF1.4 lenses as you point out, However, there are 2 versions specifcally of the super takumar 50F1.4, the earlier version is highly sought after, and has an optical design using 8 elements. It was, at the time (maybe still is) the sharpest 50mmF1.4 made.
all subsequent super takumars, s-m-c and SMC tak's plus the SMC, SMC-M, SMC-A and autofocus 50mmF1.4 lenses use 7 elements, the reason was cost.
Many of the designs ade very similar optically for all the 7 element versions, but clearly coatings will advance quite a lot.
SO when the OP asks about comparing the super tak to the tammy, the first thing you need to discuss is what version of super tak.
I have the 8 element version and the tammy,. I use them both, but notably I use the 50mmF1.4 at night wide open, so I can't compare it to the Tammy because I have a 2 F stop advantage with the Tak.
As far as I know, 8 element Takumar is more valuable because it's rare.
Sharpness-wise it should be same with 7 element Super-Takumar, not better than SMC Tamukar.
Anyway, I have all three, and it seems like it's time to shoot a test between 50mm Takumars.
images, k-mount, lenses, pentax lens, slr lens, taks, tamron
For Sale - Sold: Sigma 18-125mm, Tamron SP 90mm macro, Super Takumar 50mm F1.4, and film bodies jackmao Sold Items 8 12-04-2010 09:35 AM
For Sale - Sold: Takumar: Super Takumar 135mm f3.5 includes case, hood and caps Peter Zack Sold Items 7 05-17-2010 07:12 PM
Super Takumar 135mm f/3.5 and Super Takumar 55mm f/1.8 Fixcinater Pentax SLR Lens Discussion 21 08-30-2009 09:34 AM
For Sale - Sold: Super Macro Takumar 50mm, Super Takumar 200mm, F 35-80mm Lenses Nick Siebers Sold Items 4 02-01-2009 08:56 PM
All times are GMT -7. The time now is 07:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
