10-31-2007, 05:42 PM   #1
xs400's Avatar
Problems with Pentax-A lens on K100D
I just got a Pentax-A 50mm f/2 on ebay. I put the lens on my K100D and have had difficulty taking pictures. I have figured out how to set the aperature from auto to manual by pushing the little button on the aperature ring. My problem is that when set the aperature to A (auto) or set the aperature manually and I push the shutter release - sometimes I get a picture and sometimes nothing happens. I have tried several exposure modes, Av, manual, etc, to no avail. What do I have to do to get the camera to take a picture when I push the shutter release everytime? Right now I don't know why some times it takes a picture and some times nothing happens
Or did I just get a bad lens on ebay?
Thanks,
Franks
10-31-2007, 05:49 PM   #2
Have you tried cleaning the contacts on the lens mount?
10-31-2007, 05:59 PM   #3
Problems with Pentax-A Lens
Ther is a good Pictorial guide to using manual lenses on the K100d in the dpreview.com forum.I am contemplating purchase of aK100D after rescuing some old Pentax lenses I bought in Singapore while on R&R fromVietnam in the 60's.
10-31-2007, 06:00 PM   #4
pschlute's Avatar
With this lens leave the aperture on "A" always. You can control the aperture through the Av wheel as you would do with a DA lens.
The reason you are not able to fire the shutter always is most likely because you have the focus control set to auto focus (single) on the camera. In this mode you can only take a shot when the camera thinks it is in focus.
If you set the control to manual focus you can fire the shutter anytime.
But the auto focus setting can be useful for "focus trap" capture: press the shutter as you slowly turn the focus ring.... when the camera thinks it is in focus you will see the green hexagon light up and the shutter will fire. Even in manual focus you can still use the green hexagon to help with focus confirmation...... note the green hexagon/NOT the red square.
btw focus confirmation works only of centre point with this lens.
10-31-2007, 06:41 PM   #5
clawhammer's Avatar
Also, if the lens is set to something other than 'A' it will not fire unless you set a certain custom function, I forget whcih it is on the K100. Then it'll work, but to meter you would have to change to 'optical preview', stop the lens down, change the shutter speed til the EV rating is at '0', then take the picture- quite the pain. stick with the 'A' setting.
10-31-2007, 09:53 PM   #6
xs400's Avatar
This was the problem. I knew you guys would come through with the answer.
Thanks for your help.
Frank
aperature, auto, ebay, k-mount, k100d, lens, pentax lens, pentax-a, pentax-a lens, picture, release, slr lens, times
Pentax K100D Fireware update problems ichriz Pentax DSLR Discussion 7 09-26-2010 07:36 PM
Pentax K100D Problems pnind Pentax DSLR Discussion 3 06-10-2010 09:24 AM
pentax da* lens problems ranters Pentax SLR Lens Discussion 8 08-17-2009 10:00 AM
k100d super, lens problems (m42 to pentax K) M0ppeN Troubleshooting and Beginner Help 3 03-19-2009 02:29 PM
What problems can I expect using an M-class lens or older on a K100d? Grimlock Pentax SLR Lens Discussion 10 09-10-2007 09:31 PM
All times are GMT -7. The time now is 03:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
