Originally posted by TOUGEFC Both the F/FA 135 and DFA100 are also on my LBA list.
Sorry to go slightly off-topic but whats AF speed like on the 100?
The AF speed of the 100WR isn't too bad. It's true that if it misses focus it takes longer than a non-macro lens to cycle back and forth. But even in low light, I've found the 100WR doesn't miss much and seldom cycles through the range (at least on my K-5).
Originally posted by pinholecam For AF lenses, the 100mm macro or a used F/FA135mm.
The 100mm macro does add in the new option of macro photography.
True, and it does both tasks (macro and non-macro) very well IMO. FWIW, the FA135 goes down to 1:4, so it's pretty good for close work as well. I've also tried the FA135 with an AF extension tubes and that works pretty well for getting a bit closer.
Originally posted by axl Problem with both versions of DFA100 is missing limiter. If the lens misses the focus it takes a bit.
On the other side, the older FA100 has limiter at 70cm. And the AF between 70cm and infinity is very fast. Faster than FA ltds I'd say. Price to pay? Size...but I'm rebuying it anyway
True, if the 100WR has a limiter, it would certainly be beneficial as a telephoto lens. The focus limiter of the FA100 is nice, and the focus speed of the FA100 is very quick between the limiter and infinity. I don't think know if it's faster than the FA135 (I'll tell you on Tuesday
), but probably a bit quicker than the 100WR and FA limiteds. In terms of size, both the FA135 and 100WR are each a little more than half the weight of the FA100, which as you said, is a bit on the heavy side.
