05-01-2011, 11:28 PM   #16
Pentaxor's Avatar
QuoteOriginally posted by pencilnink Quote
Btw, is it normal for this lens to be blurry with infinity focus at all apertures?
NO !
Also, what can I do to fix this? While half pressing the shutter when focusing, the focus assist indicator beeps when everything is still blurry.
did you adjust the diopter of the viewfinder?
05-02-2011, 12:25 AM   #17
pencilnink's Avatar
I may have found the culprit to my focus problems, The lens happens to have a loose element as I can hear a little movement when tilting the lens. Would this lens be easy to open up?
05-02-2011, 03:33 AM   #18
Ya, mine is nothing like at or near infinity. It starts to become clearer between 6 to 10 meters and anything higher is a blur for distant objects.
This is probably not the answer but I just mention it - I have an FA50 1.7 that wouldn't focus properly at long distances. It must have been serviced and wrongly reassembled because the positioning of the focusing ring needed adjustment - it wouldn't turn far enough. It's fine now. I also have an M28 3.5 which I suspect has the same issue, but less.
05-02-2011, 04:52 AM   #19
pencilnink's Avatar
Ya, I'm thinking my lens wasn't reassemebled correctly or some impact on the package during shipment caused a lens element to come loose.
05-02-2011, 05:29 AM   #20
Jupiter lenses made around 1991 (time of soviet union collapse) weren't of top quality compared to earlier or the later versions. I also had a bad Jupiter which was made around 1990. I returned it and then acquired one from forum member which was made around 1959 - simply brilliant. Check this out So which Jupiter-9 is best? Old/New? - Photo.net Leica and Rangefinders Forum
This one from my Jupiter (may not be at infinity focus though)
focus, k-mount, lens, pentax lens, slr lens
Jupiter 9 ultraviolet Pentax SLR Lens Discussion 20 04-13-2011 08:10 PM
Signage via Jupiter-9 deadwolfbones Post Your Photos! 3 08-28-2009 06:41 AM
SMC-M 85/2 vs Jupiter 9 axl Pentax SLR Lens Discussion 17 05-22-2009 11:55 AM
All times are GMT -7. The time now is 01:24 PM. | See also: NikonForums.com, part of our network of photo forums!
