05-05-2011, 03:41 PM   #31
Marc Sabatella's Avatar
QuoteOriginally posted by stills999 Quote
I tested the lens focus against my 77mm. It seems that the front focus on my microwave was due to my camera having front focus in indoor light. (K-R is known for indoor FF issues it seems.)
I wouldn't have thought it would be to the extreme shown in your test chart shots, though. Dumb question, but are you sure you had selected the center focus point on those?
(Not sure why the color balance is off so much indoors ... i did not check the setting at the time.)
It's pretty common for AWB to be conservative in orangish light - otherwise, it would tend to render scenes that are really are orangish as less colorful than you'd like.
05-05-2011, 09:29 PM   #32
Yes, I can confirm that the camera has been on center focus exclusively (using a tripod). I've re-tested quite a few times and am seeing very consistent results. When I set the 'AF Fine Adjustment to -8' both the chart and other shots consistenly look much better while indoors.
Keep in mind the K-R is known for FF problems, so my results don't seem to surprising..?
05-06-2011, 08:00 AM   #33
I just hadn't realized it would be to that extreme.
05-06-2011, 12:29 PM   #34
Beach Audio called me and offered an exchange or credit (I took the credit as the lens is working fine for me).
They seemed genuinely surprised that this happened and did not even ask me to change the poor rating I had given them on amazon. I' could be wrong, but it seems this was not intentional. They otherwise have good reviews...
Thanks all for the help!
k-mount, lens, pentax lens, slr lens, spot, vendor
K-7 Defective Sensors? Loren E Pentax DSLR Discussion 16 12-11-2010 06:17 AM
Is My DA40 LTD Defective? jaieger Pentax SLR Lens Discussion 4 08-16-2010 08:14 PM
Defective meter on my new k7? pentup Pentax DSLR Discussion 11 07-04-2010 12:30 PM
BG3 Defective? Nick SD Pentax Camera and Field Accessories 3 01-27-2010 07:48 PM
Are one or more of my lenses defective? Is it the camera? Or is it me? rpriedhorsky Pentax SLR Lens Discussion 4 06-04-2009 08:33 AM
All times are GMT -7. The time now is 02:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
