05-07-2011, 08:37 PM   #1
Thales454's Avatar
Quality vs AF Speed
So after several hours browsing the internet I got the following competitors left in the ring, to be used on a K-5:
Sigma 100-300mm F4 EX DG APO (AF Lens) + 1.4x TC
Sigma 120-400mm F4.5-5.6 DG OS APO HSM no TC
Sigma 50-500mm F4-6.3 EX DG APO (AF Lens) no TC
Sigma 150-500mm F5-6.3 DG APO HSM no TC
My question is which one of them is the best to be used with those TCs?
My main priority is IQ, but as I'm not going to carry a tripod or monopod around AF Speed is extremly important as well. So forget about price, utility, weight and all that stuff, I already have a good mid range lens.
Few minutes ago I saw Piotr's pictures using the 100-300 and I have no words to describe how sharp that thing is, his pictures were more worth than a full review to me, since he took many shots with different aperture, ISO, FLs and w/ or w/o his 1.4x TC and all of them look REALLY beautiful.
You can have a look at his pictures in here:
Mauritius birds Photo Gallery by Piotr Sobolewski at pbase.com
The only thing which made me not choose 100-300 yet was his AF Speed, which I would like to confirm if it's fast and steady enough to take similar shots hand holding the camera.
I do know that Sigma 70-200 and DA* 60-250 have the fastest focus. But as the 100-300 is cheapper than the DA* and still has longer reach. Therefore, I'm here to ask what's your verdict?
Thanks for your time in advance! =D
UPDATE:
I had to change the TCs to 2x to balance the zoom range, but yes, we will have to take in account the slight image deterioration :x
I would be much happier if I could just find an album just like Pitr's from the other lenses, so I could compare them. However, I'm still looking for those...
Chart updated.
05-07-2011, 08:47 PM   #2
I don't have the link handy but someone tried out Sigma 100-300mm F4 vs 70-200+TC and 100-300 was overall better - at least the AF was much faster.
05-07-2011, 08:49 PM   #3
Thales454's Avatar
QuoteOriginally posted by yusuf Quote
Can you recall if it was a member from our comunity?
05-07-2011, 08:58 PM   #4
QuoteOriginally posted by Thales454 Quote
Pentax-DA* 60-250mm F4 ED [IF] SDM
Tamron 70-200mm F2.8 DI LD Macro
Sigma 70-200mm F2.8 EX DG APO Macro HSM II
My question is which one of them is the best to be used with a 1.4x TC?
I do know that Sigma 70-200 and DA* 60-250 have the fastest focus. But as the 100-300 is cheapper than the DA* and still has longer reach, I'm here to ask what's your verdict?
My verdict is you should get DA 21, DA 40, DA 70 and DA* 300 f/4.
05-07-2011, 09:00 PM   #5
Thales454's Avatar
QuoteOriginally posted by asdf Quote
Thanks for the advice, however I'm looking for Zooms only
05-07-2011, 09:04 PM   #6
Fatima came across Nasruddin in the living room scooting around on his hands and knees, with his turbaned head bumping around, searching intently. She asked, “What are you looking for, Nasruddin?”
“I lost my ring in the basement.”
“Then why are you looking for it up here?”
“I looked for it down there, but it was so dark there that I couldn’t see a thing. Since I knew the light here is better, I came upstairs. I still can’t find it, so next I’ll go outside, where the light is even better, and maybe I’ll find it there.”
05-07-2011, 09:08 PM   #7
Thales454's Avatar
Yes, I got your point Fatima
But I'm also a traveler in the mean time, so I don't have the necessary time to swap lenses that often and that's the main reason why I've previously asked about those specific zoom lenes
05-07-2011, 09:17 PM   #8
Well, I do own DA* 300 f/4 and not DA* 60-250, but based on the sample pictures, tests and pretty much a general consensus, DA* 60-250 is excellent optically. The problem with both HSM and SDM is potential failure. I've had one SDM motor failure (not on DA* 300 f/4 though) and had it replaced.
05-07-2011, 09:30 PM   #9
Thales454's Avatar
Ic... Well, I guess it's something that I will have to deal with :x
Could you give us an input about DA* 60-250 + TC ?
I've found the following user review in the Sigma 150-500 (which has a fairly inferior IQ) page:
"Generally I stick with Pentax lenses, but with brick wall at 300mm, I was left with few options. I did try teleconverters on my DA* 60-250 and 300, but the results were disappointing so I bought the Sigma 150-500.
Should I guess he was using a bad TC or having some kind of technical issues?
05-07-2011, 09:36 PM   #10
A TC will degrade image quality. Also, the TC will definitely negatively affect auto-focus speed because it makes the image dimmer. I've had cameras hunt far more frequently with a teleconverter, on cloudy days especially. If you start with a faster lens (i.e., 300 f/2.8) and add a quality teleconverter, you'll have less trouble with AF speed.
05-07-2011, 09:38 PM   #11
Thales454's Avatar
Alright, thanks very much for your time =D
05-07-2011, 10:04 PM   #12
It's my understanding that current digital SLR cameras won't auto-focus with an f/8 lens. An f/4 lens with a doubler becomes an f/8 lens and may not auto-focus at all. Has anyone tried the AF at f/8 ? Aside from better quality I think that may be why people use a 1.4x converter with an f/4 lens.
05-07-2011, 10:07 PM   #13
Thales454's Avatar
QuoteOriginally posted by pentaxus Quote
This have been currently stated by a user in the 100-300 page:
"I mostly use this lens for sports and at air shows. As with the 70-200, this lens also works very will with the Sigma EX teleconverters. The Sigma web site states that you lose auto focus capability when using the 2x converter with this lens. That has not been my experience. Auto focus works just fine. Must have been something the lawyers made them say. You know, to protect themselves."
I guess some of them don't have this issue :x
05-07-2011, 10:14 PM   #14
As I mentioned above, it depends on light conditions, too. If you shoot high contrast targets on sunny days, you'll have less problems.
05-08-2011, 02:07 AM   #15
Thales, apparently you're overseas (at least from a US perspective) but where do you plan on getting the Sigma 100-300? I'm looking for a copy of this lens.
af, apo, dg, k-mount, lens, look, pentax lens, pictures, shots, sigma, slr lens, tc
Is the K-x the same video quality as K-7? justtakingpics Video and Pentax HDSLRs 2 04-23-2010 10:43 PM
Looking for a good quality dardjiskien Pentax SLR Lens Discussion 4 04-07-2010 02:13 AM
Printing Quality neilj Digital Processing, Software, and Printing 5 12-26-2009 09:36 AM
K-x vs K-m JPEG quality deadwolfbones Pentax DSLR Discussion 8 11-21-2009 08:47 PM
DA* 16-50 how to test quality Burgerbrater Pentax SLR Lens Discussion 32 10-23-2009 01:35 PM
All times are GMT -7. The time now is 02:49 PM. | See also: NikonForums.com, part of our network of photo forums!
