05-08-2011, 09:36 AM   #1
Sigma 17-70mm OS quick question
Ok, I briefly looked for this but couldn't find the answer. Anyway, I read that the OS on sigma's lens really isn't that beneficial because of the Pentax's in body SR. Now, unless I am missing something here, the SR is automatically turned off when shooting with a remote on the K-x. I use a remote A LOT and so often don't have this feature available.
Most people say it isnt beneficial to dish out the extra money for the OS, but in my case if I buy the Sigma 17-70 DC OS HSM would I be able to have the OS turned on while using a remote? If so, I think the OS is definitely going to be the best option for me. Any thoughts?
05-08-2011, 09:43 AM   #2
Yes, it will stay on when using the remote. Isn't it the case that SR is only disabled when the self-timer option is engaged? Remember that when on a tripod, SR isn't going to be of much help unless the whole setup is somehow moving.
05-08-2011, 09:54 AM   #3
It is off with the self timer as well as with the remote, although I did have to go double check that. Unless I have some obscure setting changed somewhere?
I suppose that is true about the tripod although I do a lot of traveling/hiking and so the tripod I use is pretty light weight and I didn't have the money to get a nice one. So, its a little flimsy. The OS might not help much but there have been times where I am sure it would have been a little beneficial.
05-09-2011, 05:21 PM   #4
demuire's Avatar
Can the OS be enabled while the SR is enabled? If so, does that mean that it'll be twice as good?
05-10-2011, 02:38 AM   #5
QuoteOriginally posted by demuire Quote
Yes, it can be, but it means your pictures will be worse, not better. SR will attempt to stabilize an image that is already stabilized by OS, which will introduce blur from the sensor movement. You should use one or the other, not both.
05-11-2011, 02:19 AM   #6
demuire's Avatar
Hmm, that's interesting. Makes me wonder if the HSM is worth paying the extra for then, some people seem to say that in the 17-70mm the HSM isn't all that much faster than the non-HSM... Don't know if that's true though!
k-mount, os, pentax lens, sigma, slr lens, sr
Quick question on Tamron 17-50mm vs Sigma 17-50mm Edgar_in_Indy Pentax DSLR Discussion 5 11-19-2010 01:08 PM
Quick Focus Test; Sigma 24-70mm EX DG f/2.8 Macro ajuett Pentax SLR Lens Discussion 0 05-29-2010 01:21 PM
Quick question about flashes: AF 360 triggering Sigma 530 Andi Lo Flashes, Lighting, and Studio 3 07-28-2009 08:24 PM
Question: Sigma 70mm macro truonganh Pentax SLR Lens Discussion 8 03-07-2008 07:00 PM
Sigma 70mm DG Macro question mysterick Pentax SLR Lens Discussion 2 02-07-2008 12:19 PM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
