05-09-2011, 06:58 PM   #16
wizofoz's Avatar
This is a re-branded Samyang lens. I had one before it was stolen and loved it. It has a special quality about it. I paid AU$400ish for it, and it was worth every cent. KA mount with aperture ring.
05-10-2011, 03:04 PM   #17
selar's Avatar
QuoteOriginally posted by sadeq-x Quote
If you see an A position on the aperture ring it indicates its a PKA mount. I can see an A position in that picture.
05-10-2011, 03:24 PM   #18
joe.penn's Avatar
The Rokinon Branded ones are KA mounts on all of the samyang manufactured lenses...
05-10-2011, 08:26 PM   #19
RioRico's Avatar
QuoteOriginally posted by jstevewhite Quote
Have you posted any pix of or with your conversions?
If I started posting results pictures, I'd have ZERO time left for anything else! As for the conversions of N/AI, OM, C/Y, Petri, and Exakta mounts, I've documented them both here and on the MLFenses.Com forums, some with photos. But they're mostly simple enough that words suffice.
The N/AI-PK conversion (destructive): The aperture ring has "nub and arc" protrusions. I use a Dremel metal-cutting blade to cut those off, then a sanding blade to smooth the bottom of that ring. When the cutting blade has worn down to about 12mm / 0.5in diameter, I cut a slot about 1mm deep and wide and 5mm long in the N/AI lens base, for the PK locking pin to engage. Blow all the dust away, and the lens will now lock into a PK mount and will (safely) shot the mount pins, thus enabling CIF.
My workshop: In good weather, I work on a 2x6in back-porch railing. In bad weather, I put a 1x8 plank over my bathroom sink. Only the finest facilities, eh?
05-11-2011, 06:16 AM   #20
thanks guys 4 ur opinions and discussions
05-18-2011, 08:46 AM   #21
Just pulled the trigger on the Rokinon version, supposed to get it today. *Excitement*
05-18-2011, 08:50 AM   #22
joe.penn's Avatar
Bought the Vivitar last week from B&H, insaneeeelllllllyyyyyyyyy good lens...
05-18-2011, 11:35 AM   #23
QuoteOriginally posted by icywindow Quote
Lookin' forward to sample images!
05-19-2011, 09:11 AM   #24
Got it this morning; it's on the K20D, and I have taken about 20 shots with it.
First impressions:
It feels pretty heavy for the outside being polycarbonate. The front element doesn't look as big as it is. The lens mounts pretty tightly to the camera. Turning the focus ring takes some effort, and it has no momentum (that is, starting turning the ring does not make it any easier to move). The finish of the outside of the lens feels cheap.
After a few shots, it seems to me that the optimal range is about 6 feet away. The front element lets _so_ much light into the camera. The DOF is frustrating for focus, but it does "magically" come into focus as you turn the focus ring. You get the idea pretty quickly that it works best if you can take your time for the shot. Shots ranging from f1.4 to 2.8 all are rather sharp at the focus point, and bokeh is creamy and delightful.
I am frustrated by this lens, but not because of the lens - instead because it cuts against my (lack of) skills. I think this Rokinon's going to be on my camera for a good while to train my eyes for focus and DOF.
I'll post pictures after this weekend.
05-19-2011, 03:44 PM - 1 Like   #25
It's actually both metal and polycarbonate, the outer front (focus ring/filter threads) is where I think most of the plastic is.
It's the tightest fitting lens of all of my lenses by a good margin. Not sure what's up with that.
I wouldn't say cheap... but I wouldn't say luxurious either. Somewhere in between. In fact, I noticed that the texture pattern of the lens finish (Rokinon at least, and I assume the Vivitar is the same and they only changed the rubber grip pattern and text coloring) is an almost identical match to my K200D, and I don't think that feels cheap.
I'd strongly recommend a replacement focus screen and a Pentax O-ME53 or Tenpa 1.36 magnifying eyecup. They help a lot.
05-19-2011, 07:12 PM   #26
+1.
As far as my cheapness comment, it felt like the plastic wasn't finished or sanded, so it has speckles on the finish. Not really a big deal.
Also, the sharpness of this thing even in low light is lovely. I had to post this shot, just taken wide open, pointed directly at the mirror. My stance is wrong, but this is the best one of the bunch. I love this lens.
and cropped:
05-19-2011, 07:52 PM   #27
joe.penn's Avatar
QuoteOriginally posted by nater Quote
The Rokinon FE lens is also an extremely tight fit. Oddly enough, I have the Vivitar version and the fit actually feels normal...
05-19-2011, 08:31 PM   #28
thanks icywindow and all 0f u guys
05-20-2011, 12:16 PM   #29
I ordered a Tenpa on your recommendation. Looks interesting. I've got a question - can you see the whole screen with the Tenpa in place, or just the center?
05-20-2011, 02:29 PM   #30
I only have direct experience with the Pentax O-ME3, but based on reviews of the Tenpa, as long as you don't wear glasses, you'll see the whole screen, but might have to move your eye a bit to see the info display below the viewfinder image.
dollar, guys, k-mount, lens, pentax lens, slr lens, vivitar 85mm
For Sale - Sold: Novatron Flashmeter, Vivitar 85-205mm f3.8 lens, Vivitar S1 35-85mm thazooo Sold Items 4 03-24-2010 03:09 PM
Jupiter-9 vs. Samyang/Vivitar/Rokinon/etc 85mm deadwolfbones Pentax SLR Lens Discussion 3 10-23-2009 05:47 PM
Vivitar 85mm MF lens Leya216 Pentax SLR Lens Discussion 4 10-03-2009 06:31 PM
All times are GMT -7. The time now is 01:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
